Question about Panasonic RR-930 Desktop Cassette Transcriber / Recorder
Spindles for the cassette do not turn
Need immediate assistance
    President:
  • 2,992 Answers
There is a rubber drive belt inside that needs to be replaced. It is Panasonic part number RDV101YA and this website says they have it:
http://www.partstore.com/Model/Matsushita/Panasonic/RR930.aspx?ModelAliasNumber=rr-930
I've never had to work on one of these machines so I can't tell you exactly what you might need to remove to get at the old belt and pulleys it rides on, but usually it isn't too bad of a job. Anyone with some patience and who is comfortable with small tools should be able to change it. Just keep track of what screws came out of where, what other pieces had to be moved, etc. so you can put it all back together. (Camera phones are great...you can take pictures at each step so you can look back.)
Posted on Dec 05, 2008
Dura brand,why is the tape coming out of the cassette when I pay it?
Hi there
This is an answer which is general to all tape cassette decks. I think it probably applies to yours but this may or may not be the case.
The tape is transported past the "read" head by a pinch wheel and spindle that come up into the cassette on either side of the tape. The spindle runs at a very constant speed and with the tape between this and the (rubber) pinch wheel sounds are transferred fro the read head to the electronics for amplification etc. We are not concerned with that here but with what physically happens to the tape after the pinch wheel. Under normal circumstances a belt is driven from the electric motor to the take-up reel of the cassette. This usually runs slightly faster than the spindle/ pinch wheel so that the tape winds cleanly onto the take-up reel. If this belt is loose, has come off entirely or is otherwise not working properly, then the spindle/pinch wheel will continue to feed the tape but it has nowhere to go because it is not being wound onto the take-up reel, except out of the cassette into the tape desk mechanism. In this case it often gets wrapped around the spindle/pinch wheel assembly and gets into a very nasty tangle, causing serious damage to the tape and possible damage to the deck.
Hope this explains your problem.
Cheers
Nov 10, 2014 | Audio Players & Recorders
Only one spindle turns on cassette player
It is probably a loose or broken belt. I do not know the unit so this is just a starting point.
Aug 10, 2014 | Aiwa Audio Players & Recorders
Cassette deck stops immediately after pressing play
It is likely that the rubber drive belts have deteriorated and will have to be replaced to restore operation.
Apr 21, 2013 | Audio Players & Recorders
Cannot seem to remove the ribbon cassette from IBM Selectric II. Would like to place it in another Selectric II that runs well but has no ribbon. I pulled the lever on the right but the right side of the...
Pulling the lever on the right of the cassette should move the ribbon drive spindle out of the cassette and leave it free to remove, but sometimes the ribbon can become twisted on to the drive spindle and it won't disengage. If that has happened you will have to break open the cassette to free the spindle.
May 01, 2010 | Office Equipment & Supplies
The power is on but the motor will not turn the tape drive. Does anyone know a good repair shop?
Hmm, when you press play, can you feel the motor turning, do the spindles turn on fast forward or rewind? If so you may have one of two problems. First check to see if the cue button is is depressed. If it is jammed, the deck will FF and RR but won't play. If it's not that, but the motor still spins, the motor is no longer making contact with the flywheel. If you have a repair manual, dismantle the deck and check out the motor contact
May 10, 2009 | Sony Walkman WM-D6C Personal Cassette...
Dictaphone indicates end of tape
The sensor that detects the tape movement is bad and will need to be replaced.
Nov 10, 2008 | Dictaphone 2741 Desktop Cassette Voice...
How do I open a Maxell mini DV tape case? I have one cassette that is broken - tape is fine - I need to transfer the tape reels to a new cassette. Same brand of cassette.
Hello FixYa, I was able to find a post in the internet to help. While you service is convenient, the cost and my immediate need really dictated my continued search. Thank-you anyways for your time.
Aug 11, 2008 | Maxell CD-R 80 Minute 700MB Media...
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
The cassette spindles do not turn at all
Check for broken or stretched rubber drive belts. Age is as bad an enemy as wear. If it has been sitting for a period of months they go bad faster. Even if you keep it indoors out of the heat, the A/C will dry out the oil the belts and they wil lose their elastisity. There are usuallyonly about 3 or 4 belts in the cassette player at most and they cost less than a dollar each. If you can find the belts, buy extras and keep the extras in a zip lock bag. Parts are harder to find as time goes on and most manufacturers will deliverately quit selling normal wear items like belts after a few years to force you to buy a new product.
Jan 15, 2008 | Lenoxx Electronics CD-102 Cassette/CD...
Panasonic RR-930 Desktop Cassette Transcriber / Recorder Logo
323 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
