CD Player Skipping And Spinning Backwards!
Hello. I have a Micromega Leader II CD player which uses a Phillips swingarm transport. For a few years now the player has often been reluctant to start playing the disk but it has now deteriorated. When play is pressed the disk will spin, then the lazer head will flick back violently against the rear of its slot and the disk will spin at high speed in reverse! If and when I does start to play it starts to distort and skip towards the end of the disk and going to the next track will cause the flick/spin trick to be repeated. I have no idea what could cause this bizarre behaviour. I like the player so would be keen to fix it. Any help would be gratefully received. Thank you.
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
petraman7
  • 1175 Answers
SOURCE: player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Posted on Jan 01, 2009
AREA51S4B
  • 30 Answers
SOURCE: Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Posted on Jul 27, 2009
littlepear
  • 7 Answers
SOURCE: used 200 cd player keeps skipping
I just fixed this using Scarthhouse's solution of removing the sensor assembly, cog, and squeezing the rack (of the rack and pinion) together (I squeezed the metal bar upwards). I'm not even electronically-inclined, so I'm ecstatic that this fixed the used 300 Sony disk player I just purchased.
Posted on Dec 30, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: 3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Posted on Mar 08, 2010
Testimonial: "Very informative regarding my problem. Pgh also went to the trouble to ask what the model number of my stereo is in an effort to help me locate a part"
Skips when playing CD or DVDs
First try a cd head cleaner. It has to work well enough to ffwd to track 4 or as instructed. If that does not work you need to open the case. Unplug power as the laser can blind you. 5 screws on the back and one each side. Lift the lid from the back to about 30 degrees and pull/ wiggle it off. Use a cotton bud wetted with alcohol (Isopropyl or surgical). You need to wipe the glass lens very very gently. wipe dry with other end of cotton bud. Recover and try.
While covers are off look for bulging capacitors or signs of black overheating.
Jan 24, 2013 | Jamo DMR 60 DVD Player/Receiver
Kenwood portable cd player dpc-741 skips.
Hello
The skipping happens because the lens is weak,to solve this problem open the cd player so you can see the lens.Clean the lens with cotton wool dabbed in a little methylated spirit(wipe carefully).This should stop the skipping.
If the skipping continues then the lens is too weak to play CD's so it is best that you change the lens of your CD player.
Aug 11, 2010 | Kenwood Audio Players & Recorders
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
Blauplunkt car cd player skipping
If your new cd is skipping in your cars cd player, your cars player might need cleaning or there could be a problem with the cd.
  • examples are good so here are some
  • example is : that you just need a new car
  • cd is 8 or so years old
  • and more
my cds are always old
Dec 05, 2008 | Car Audio & Video
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
I have a micromega stage 5 and the disc is jittering in the drive, i.e not spinning any idea's?
Had the same problem I think. When I would load a disc after a few seconds the unit would read no disc. I opened the unit and removed the transport and there is a board under the laser unit, on that board there is an adjustable pot so I plugged the module to the main board and powered the unit up. I adjusted the pot then sat a cd on it until I found a setting that worked. I hope this helps. I am not sure of your ability. Something to remmember is you can only fix it or break it.
Oct 20, 2008 | Audio Players & Recorders
CD Player stopped working
Probably there is dust on the lens. My CD player (different brand) did the same. I opened the case and cleaned the lens with a photo camera brush (VERY gently). Now it works fine.
If you cannot / do not want to open the device to access the lens, you may want to buy a cleaning CD.
Aug 01, 2008 | Coby CXCD395 Shelf System
Skipping
Skipping
Remove and replace the graphite grease from the laser transport worm gear assembly (use the correct Technics stuff), replace the worm gear drive belt, and ensure that the tension spring on the C-shaped plastic piece that rides the gear is OK
Nov 23, 2007 | Durabrand DUR7 Portable DVD Player
Cd player skipping
The DVD transport rides on chrome rails. These get dust and stuff on them and wont allow the optics to track.
If you dare, open the unit UNPLUGGED from the AC.
See if you can get at those rails easily. clean with WD40 on a swab. clean with a new swab . then a couple drops of mystery oil on a swab and run down the rails over and under.
You must be VERY gentle if you clean the lens with isopropyl
Oct 05, 2007 | JVC XL-MC2000 200-Disc CD Changer
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
118 people viewed this question
 Grubhead
Grubhead
