Question about Kenmore 14249 Dishwasher
Kenmore 14249, Very poor cleaning
I ran the machine through a complete cycle to see what I could find wrong. It filled up with soapy water and also the rinse water was not very clean looking. I started the cycle again and put 1 cup of vinigar in at each rinse to clean system. This did not help. The glasses still had a grit like substance on them and when I wiped the glasses with a towel it smeared the glasses with a greasy look. I have had service guys from Sears out several times and still have bad results from this unit. I am about ready to toss it in the trash.
SOURCE:
catriver
  • 878 Answers
SOURCE: dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Posted on Nov 25, 2006
  • 338 Answers
SOURCE: I have a Sears Kenmore
call sears service and tell them you need service there is a service flash and will be no charge
Posted on Dec 23, 2008
SOURCE: Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Posted on Feb 15, 2009
localwonder
  • 6784 Answers
SOURCE: Kenmore Elite dishwasher not cleaning well and
Check the following to address this issue
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Posted on Jun 04, 2009
erpaalai
  • 999 Answers
SOURCE: leaking Kenmore Elite at the right front of dishwasher
Sorry to hear of your plight. My advice is to ask for a new machine under the lemon law since they cannot get it fixed. You can also try calling Whirlpool who is the manufacturer but they are likely to tell you to work with Sears. They were out under warranty and it has not remained fixed so the warranty should carry through since you called for service while still in warranty. I feel for the tech because it is frustrating to have a problem that you cannot find a cure for be the tech should also have escalated it to the tech support line for resolution. (I was a Sears tech for 21 years)
Posted on Sep 15, 2009
Leaks water out of vent on sink during drain cycle
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
Aug 29, 2011 | Kenmore 14249 Dishwasher
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Kenmore HE3t Frontloader Fills Up With Water After Cycle
inlet valves have possibly gotten dirt in them and need replaced . quick fix , is turn the water valves off behind the machine
Nov 07, 2017 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 14249 Dishwasher Logo
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
