Question about Refrigerators
Model # for refr. 106 50037000. module # for ice maker 106 626636. it quite.i felt the ice froze in the maker but it didnt flip it out. i took the maker out let the ice melt.put maker back in , it worked for a week & quite.i took it out again let it melt, put it back it worked 2 days & quite . help me please.
    Sniper:
  • 56 Answers
Sound the the bi-metal is starting to fail or the freeezer is not getting cold enough. If you put a thermometer into the freezer and it gets below 8 degrees and does not harverst then your looking at the ice maker which is a Whirlpool part number 4317943. This a kit will replace most of those style ice makers. It is the quickest and easiest way to solve your problem. You should be able to get it for between $85 to $160 depending on where you live and who you buy it from.
Posted on Dec 05, 2008
I have a whirlpool and my Ice maker started chunking out ice and water came out the door and warped my wood floor. Pulled out ice maker part 106 626636 and deiced everything. Noticed that the coating on...
i think you damaged the icemaker l to v is line voltage to valve . . only connection to be used with jumper is t to h this will run the motor till its started the harvest then pull wire and let it run on its on this will start the mold heater and run the drive motor and when it has almost completed the cycle it will call for water from the valve . / you need a new ice maker anyway . so just replace it and you''ll have ice i a couple of hours .. mm
Jul 30, 2010 | Refrigerators
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker not producing ice
Check your water valve first. It is usually in the back of the machine on the bottom. If your water valve is bad the it will not fill with water. When it does fill with water and it does rotate to drop ice but doesnt drop it that is probable the heater on the bottom of the ice maker not working.
May 12, 2009 | Refrigerators
Ice Maker problem 106-626636, too much water!?
Sears Had a couple of problems with this. They have a plastic tube they put on you ice make line that goes to the fill tray about 3 in long . You can make you own its just pvc pipe. The other thing is that the drain hole get froze over time and has you looking all over for a leak. The fix for this is a small strip of aluminum about 1/4 wide and 3 and a 1/2 long (pop can) rap it around the defrost coil 1 time and put about 2 in. down the drain hole. Now it can never freeze shut again. If you wan to buy the part its called a heat probe ( peace of tin) its about $20.00
Apr 27, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Kitchenaid ice maker water flow will not activate
You can post your the problem at my site by clicking the link below. Then click on free diagnosis, enter model number and the details and it may take a couple days to get the answer, but free. Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Pull the front cover off the i/maker. There are holes on the module(the piece with the large gear) They are labeled T an H at around 5 oclock L and V around 6-9 oclock use a piece of wire to jumper l and v first it should start to fill if it doesnt the fill tube may be iced up, if it does fill then jumper t and h for about 6-10 secs or until it will advance by itself. Also whirlpool had a batch of faulty modules the large gears were breaking if it wont advance or if the plastic gear falls off easily then this is the problem. Dont forget to rate my solution!! Thanks!!!
Oct 01, 2007 | Refrigerators
Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
POSSIBLE YOU HAVE 2 SEPERATE WATER SOLENOIDS. THE SOLENOID FOR THE ICE MACHINE HAS A STRAINER AND ORFICE JUST INSIDE THE INLET SIDE OF THE WATER CONNECTION. CAREFULLY REMOVE THE ASSEMBLY AND CLEAN-IT. YOU CAN CHECK IF ICE MACHINE SOLENOID HAS POWER BY TAKING A METAL BUTTER KNIFE AND HOLDING IT JUST ABOVE THE COIL ... THE MAGNETIC FORCE SHOULD BE FELT TUGGING THE BLADE DOWN. LOSSEN THE NUT ON THE OUT-LRT SIDE OF THE ICE MACH. SOLENOID AND SEE IF YOU HAVE WATER ...
Apr 26, 2007 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
651 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
