Question about Cameras
Camera says card is unreadable
I have an hp photosmart 945 ever card i put in it it says card is unreadable i have tried 256 mg-1gb and thay dont work even if there is not a card in it it say card is unreadable i got this camera from ebay so i wonder if there is some thing wrong with it like maybe the card slot is messed up on it
  • Cameras Master
  • 6,487 Answers
First thing you can try here s to reset the camera to its default settings using the reset option on its Menu, then if after that still have the same problem the card slot is some kind of bad already and it will be better to take it to a repair center near you...
Posted on Dec 07, 2008
    President:
  • 2,110 Answers
Yes You have some problem with Circuit...So it is better to take it to nearest service center...
    President:
  • Cameras Master
  • 1,314 Answers
If you've tried multiple cards on it and you know the cards are good, then the reader itself is defective.
HP Photosmart R725 card is unreadable just put in new SD card HELP!
Are you sure it's an SD card? The R725 works with SD cards 2GB or smaller. It will not work with higher-capacity SDHC cards.
Jun 09, 2014 | HP Photosmart R827 Digital Camera
945 card is unreadable
What type and size memory card?
Apr 14, 2013 | HP Photosmart 945 Digital Camera
My hp photosmart r707 gives me a message (card is unreadable) i have inserted a new card and i get the same message each time.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
One thing you could try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible. However, I would expect the camera to report that the card needed formatting rather than that it was unreadable, if formatting was the only problem.
Nov 03, 2010 | HP Photosmart R707 Digital Camera
Does Hp 945 work without a memory card
Yes, but the camera has only 32M of internal memory so you won't be able to take and store more than a handful of pictures. For "real" use you'll need one or more SD cards. Make sure you get SD cards 2GB and smaller, not SDHC cards.
Aug 18, 2010 | HP Photosmart 945 Digital Camera
I got a 4gb memory card-SanDisk and the camera says it is unreadable.i had a 512mb card and it worked fine.
Hi Tomcat,
this will not work.
The HP 945 does not support 4GB cards.
4GB (or more) are SD-HC (High Capacity). This is new format which only will be supported by newer camera models.
Jan 10, 2010 | HP Photosmart 945 Digital Camera
Card locked?
hi, if that would have happend to me the first thing i would try is to clean the SD card socket with alcohol.
open the camera and gie it a try.
Jul 11, 2007 | HP Photosmart 945 Digital Camera
Camera won't work
HP technical Support is the 1st place to go - in case there is a repair/replacement solution. If the camera is over a year old - an economical repair is unlikely
Jul 09, 2007 | HP Photosmart 945 Digital Camera
HP 945
I have had this problem with my 945 as well, the only way I could get it to stop was to take the batteries out and leave them out for a while.
May 02, 2007 | HP Photosmart 945 Digital Camera
Hp 945 Digital Camera
hi there, try another SD memory card, i had the same problem.. but then i bought a new card and the problem was solved... best regards, Richard.
May 06, 2007 | HP Photosmart 945 Digital Camera
HP Camera won't turn on
I had the exact same problem. I turned on my HP Photosmart E317 camera and it would light up for one second and then just a blank screen. Here's the tech support site from HP. Try taking out your memory card and then turn it on. That worked for me. I just put the memory card back in and it works fine. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709691&lc=en&cc=de&dlc=de&product=445953&rule=2137&lang=de
Nov 16, 2006 | HP Photosmart 945 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
