Question about Sanyo DS24425 24" TV
Sanyo DS24425 Intermittent Discoloration
Just left and right of center there are two oval areas that will turn green/purple if that area is white/light brown for more than approx 30 seconds. Color will slowly return to normal when image changes. Purchased a Sanyo DS24425 but returned after a few weeks for another of same model. New one is doing same. Powering off/on will clear problem, but it will return when those area are white/light brown again. DVD and VCR are located 30" below TV. Nothing else electronic within 5' of TV. Any help is appreciated.
  • Anonymous Jan 12, 2008
    I have green and purple oval blotches that appear when I am watching tv and have my dvd paused.
  • dmammone Jul 29, 2008
    I have the same issue.
    Could this be an issue that a degauss could correct?
Speaker location inside the set is too close to picture tube and the magnet is interfering with the picture no solution
Posted on Oct 05, 2008
    Sergeant:
  • 308 Answers
It seems like this problem would have to be with the picture tube itself, although I have never run into this symptom in over 30 years of servicing TV's. If the CRT is still in warranty I would get it checked out. Otherwise it probably not be worth repairing. If you end up replacing the set, check out the Toshiba 24" model. I have had good luck with that model in the past.
Posted on Feb 11, 2007
Hello, I have a JVC HD-61FN97 TV. I had to replace the old lamp (recommended by the TV's timer)with a new lamp. I clean out some dust in the housing and installed the new lamp. It looked great! but...
Did you use an after-market lamp?
Sometimes after-market lamps cause this defect. Even if it is the OEM lamp, I think it is worth to try a new lamp. I would return the one just purchased as defective.
Jan 25, 2015 | JVC Televison & Video
How do i eliminate the vertical green lines on the projected area?
Sadly the LCD/DLP wafer is failing, and the problem will progressively get worse. The DLP wafers can be replaced but it may cost as much as replacing the entire projector with an updated one. SORRY!
May 26, 2014 | Sanyo PLC SU20N Multimedia Projector
My 32" sanyo picture goes green
needs resoldering, in the heated areas, such as, crt socket board, power area, and high voltage area....it will be back to normal...
Oct 20, 2009 | Sanyo DS32920 32" TV
Tv wont turn on. we've had some lightning in area.
check your powersupply AC fuse and. your DC fuse. they are marked F1, F2, etc.on the circuit board and, are usually glass tubes with metal ends you should see a wire inside connected to both ends if the wire is broken replace the fuse
Aug 28, 2009 | Sanyo DS24425 24" TV
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
Needinfo on what wire does what on the Kenwood Excelon DDX7015, on the main harness and the little 3 wire harness near the center,
yellow-constant
red-accessory
if there is a light green,pink,or brown one is is us for brake ,
purple/white -camera or green/white
green/black-left rear- spk-
solid/green-left rear-spk+
purple/black-right rear-spk-
solid/purple right rear spk+
gray/black-right front spk-
solid/gray-right front spk+
white/black-left-front spk-
solid/white-left front spk+
brown or orange if any phone mute
black -ground
pink/white or purple/white or green/white-reverse camera''
Jul 10, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Color on screen is not uniform
get a degaussing coil. crt magnatized..or worst shadow mask broken loose inside crt.  to ck turn on hit crt with open palm. if colors move bad bad.
Nov 12, 2008 | Sanyo DS27800 27" TV
Screen discoloratiom area
It's definitely your VCR that is causing the problem. Move your VCR, if you don't get any results you need to send it to repair.
Jul 10, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sanyo DS24425 24" TV Logo
131 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
