Looking for owners manual for MCS Belt Drive Turntable model # 683-6710, or setup instructions.
Posted on Dec 05, 2008
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
Prolectrix usb turntable
Getting drive belts is easy, fitting them is the problem. If it is still attached in any way make a note or a photo of how it is fixed. This will help to putting a new one on. Measure the diameter of the old belt in mm. You will also need to measure the thickness in mm too. Then put these words into Google: "Turntable Belt xx mm" (use the diameter measurement in place of the XX). Then search the results looking for something that is very close to your belt. If you find the belt, try searching again for the fitting of it. Quote the model number of the turntable. The fitting instructions might even be found on this site.
Feb 27, 2014 | Audio Players & Recorders
Turntable manuals
Hi, I am looking for a manual for a Bush SRP 52 record player as the turntable won't turn and I find it find out what the problem is. Is it a belt drive turntable. How to dismantle it and look inside.Thanks
Jan 03, 2014 | Audio Players & Recorders
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
Hello My turntable do not spin
This turntable is a belt driven type. The belt wraps around the underside of the platter and the drive motor spindle. If the belt has slipped off, broken or is so old that it is slipping - the platter will not turn. Usually you can remove the rubber cover on the top of the platter to use access openings beneath to put the belt back on.
The turntable product brochure, owner's manual and related info is available from Pioneer, here.
I hope this helps!
Dec 03, 2010 | Pioneer PL-990 Turntable
I am assembling a sony turntable and don't understand step 3. Using the ribbon, loop the drive belt around the motor pulley. PS-LX300USB model Thanks
Manuals and belt instructions here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=PSLX300USB&LOC=3
You would handle the belt by the ribbon instead of bare fingers so your finger oils wouldn't contaminate the belt. You stretch the loop of the belt over the drive pulley between the flanges to hook it.
Nov 07, 2010 | Sony PS-LX300USB Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Ion ittusb turntable drive belt
If the belt is stuck, it will be hard to take off without damaging the belt. Send it back.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Jan 28, 2008 | ION Audio iTTUSB Turntable
Belt Drive
The belt is replaced as in the following diagram from the manual that you can download on the link below: http://www.lpgear.com/at_pl50_om.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Audio Technica AT-PL50 Turntable
420 people viewed this question
 Grubhead
Grubhead
