Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Fridge not colling-hotpoint HSS25GFPAWW SIDE BY SIDE
PUT NEW mother board in and temp sensor, still not cooling fridge, the trap door opens but do not think for long enough. is it the temp control board??
    Problem Solver:
  • 8 Answers
It could be one of many problems but will most likely be a refrigerant leak in the refrig evaporater
Posted on Jan 23, 2009
Where is the defrost timer on model HSS25GFPAWW side by side fridge
on this model it is included on the main circuit board # 8010fe6e279-086d-4a6a-8771-05f57d99721e.gif
Mar 22, 2014 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint model HSS25GFPAWW. It stopped cooling, fridge and freezer side. Removed the back panel, fan was not on and compressor was hot.
Unplug the refrigerator, remove the relay from the compressor and give it a shake. If it rattles, it is bad and needs to be replaced. Here is that part. But, since you said the fan was not running I suspect the control board is bad. Here is a link to that part also.
Keep me posted as to your findings.
Oct 18, 2012 | Hotpoint HSS25GFP Side by Side...
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
Jun 05, 2012 | Hotpoint Refrigerators
Hello, My fridge side of my hotpoint model # Hsm25gftc sided by side fridge/freezer isn't getting cold anymore. I purchased it in 2007 I believe. I've tore the ice maker and tray out and pulled...
if the freezer is working fine it sounds like you could have a bad damper control,also there's another thing i want you to check first,hotpoint is a g.e. product,they have sensors in the machines,you said you had the back wall off,take it off again and on top of the evap coil you'll see a sensor,it looks like a white bullet with two whits wires going to it,look at it and if where the wires connect to it it has a black ring around it you have to change it out,also ther's one of these sensors in the fidge section too,it senses how cold the fridge is and tells the damper door to open and close,it sounds like your damper is staying shut,the part number for the temp. sensors are WR55X10025 and it's like 8 dollars,if they have the black ring on them they most likely are your problem,the new sensors are all white,if you have the white sensors then you could have a bad damper.go to this site,it's sears site http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Refrigerator-Parts/Model-HSM25GFTCSA/1811/0165000/H0712760/00006?blt=06&prst=&shdMod= go to the fresh food diagram and look at the damper and the sensor,one of these parts are badmalso g.e. has had alot of problems with the mother boards,the computer board in the back of the fridge,if the condenser fan and evap fans are running fine and the freezer is fine then i would replace the damper and the sensor but change out the sensor first because it's 8 bucks,if that doesn't do it then buy the damper,all it does is the fan blows cold air from the freezer to the fridge section,if the damper isn't opening the air can't enter into the fridge section.hope this helps and points you in the right derection,let me know how you make out,good luck salde
Aug 12, 2011 | Hotpoint HSM25GFRSA
My hotpoint side by side hss25gfpaww is not cooling on the fridge side but the freezer seems ok. Fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Hotpoint HSS25GFP Side by Side...
GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer is cold but not fridge
there is a little trap door at rear upper corner of frig/freezer. (side by side type) Not sure where it is on others. Opens to cool refrig side closes when right temp is reached, Either link to operator is frozen or broke. Should be fixed (replaced) by repairman, easy, fast not too expensive.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
What next??
The 650 has it's own cooling unit unlike most refrigs,there is no trap door. The problem could be one of many but a refrigerant leak in the refrig evaporater is where I would look
Dec 09, 2008 | Sub-Zero 650 / O Bottom Freezer...
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
191 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
