Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Bissell proheat 1698 cleaner not spraying water
Our carpet cleaner is not spraying any cleaner/shampoo mixture, although all belts and the motor seem to be working just fine. Heater is also working fine, and brushes are turning.
  • DUFF2 Nov 20, 2007
    OUR BISSEL WONT SPAY OR PUMP ANYTHING OUT BUT IT WILL SUCK UP AND HEATER WORKS REPLACED ALL BALTS , HEPL PLZ ITS NOT EVEN 6 MONTHS YETS
  • Anonymous Jan 18, 2009
    I have had the same problem many times. Actually, about every other use. The place that used to fix it refuses now, saying it is junk...
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Posted on Jul 14, 2008
I noticed that the straw that draws the fluid in was at the top of the reservoir -- and all of the fluid was at the bottom. Bend the straw so that it is IN the fluid and therefore able to distribute it.
Posted on Aug 06, 2008
  • 48 Answers
If water is coming out of the hose and not the spray tips,
try taking of the handle ,
put a small thin shim on the bottom of the plunger at the bottom of the handle ,this will make the plunger make full contact with the valve,
Posted on Nov 19, 2007
  • 1952 Nov 22, 2007
    make sure the bottom tank seals and solution bottle seals these are small red round seals are still attached to the bottom of the tank and bottle ,
    also make sure the brush is still spinning round,
    see if water is being dispensed from tho hose.
    make sure the handle plunger wich is at the bottom of the handle is meeting the valve
The little red dial on mine was not turning. Checked all filters and plungers and those seemed fine too. I noticed the red bristle brush was not turning. I turned over the machine and found a bunch of dog hair was caught up on the bottom including the spindle attached to the brush. Cleaned everything out and made sure the brush was turning again. Water and cleaner came out just fine after that.
Posted on Jan 28, 2010
  • 701 Answers
If it is not dispensing water or solution it can be because the pump belt is stretch or worn and needs to be replaced. Here is the proper replacement pump belt:
Bissell Proheat Pump Belt
Posted on May 25, 2010
I am pulling the trigger and the carpet solution won't spray out
too much cleaner in the mixture, do you see the little fan type thing in the window spin usually when you dispense cleaner well it won't spin and dispense cleaner if you get it too soapy or concentrated.
Jul 07, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Using the bissell proheat upright carpet cleaner and no shampoo is being dispursed.
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jul 03, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
No water or solution spraying
Used an air compressor to clean out the clogged tubes
Jul 18, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
A solution to many "non-spray" problems.
The Scotchguard is going to be dicey inside the Bissell, yes, as you have learned the hard way.
I think the Bissell and the Hoover shampoos sold for their carpet cleaning machines are reasonably safe to use in the Bissell. My own personal favorite for use with the Bissell is the Hoover Premium Pet Formula, which is pricey but effective even if you don't own pets. I also pre-treat stained areas with Resolve Carpet Cleaner, a few minutes before using the Bissell.
I don't know what will happen with your home brew containing Dove. It may work well.
Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
May 25, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to use bissell carpet cleaner
On the 1698 modle thier is a large clean water tank and a smaller shampoo bottle which seats on the side of the machine.
the shampoo goes in the smaller bottle fo the two.
Jan 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
3,852 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
