Question about Philips Televison & Video
HDD DVD player. Problems recrding on dvd r discs. dvd rw seem to be OK
  • 120 Answers
If you are speaking in terms of the disk playback on another machine, use DVD-R disks (if supported). DVD+R will not play on older machines.
Posted on Dec 05, 2008
Won't work with the same kind of discs i've used before
I not sure as to which type of Discs that you are refering to (ie DVD+R or DVD+RW). This player will only recognize 4x (max) DVD+RW and 8x (max) DVR+R discs. If the DVD+R Disc is 16x, the DVD recorder will not recognize it once you start to record. The player will read the blank Disc and give the impression that it will record on it. I have noticed that when a 16x speed Disc is in the Drive, The recordable hours for the disc seems to double. The normal 6 Hour recording length comes up as 12 Hours when you hit the info button. Since the 8x Speed (max) discs are not available any longer, I found it best to use the DVD+RW 4x Discs and make it compatible. I then copy the compatible DVD+RW disc to a 16X DVD+R disc using my computer DVD burner. The DVD+RW disc can then be erased so that it can be reused.
Nov 23, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
My LG DVD RECORDER, MODEL RH7500 won't play DVDs.
Check the model specifications for your device. Some players will only accept DVD-R and not DVD+R or not DVD+RW discs. I know it all seems the same, and it's very frustrating, but many companies restrict the type of discs they will allow. My player does +R but not -R. It should still be able to read DVD discs that you made yourself, but they will be of a different type.
Nov 03, 2009 | Televison & Video
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
I have a hdd/dvd recorder model rh7880/rh7500 set timer recording to record onto dvd, machine switched itself on as normal but did not start to record and froze up.cannot get anything to respond either...
Recorder wasn't under warranty, so opened the unit up removed the dvd - rw disc ,which was corrupted as it turns out, put the machine back together switched it on and it worked perfectly.I have since tested it by recording both on to dvd,hdd and used the dubbing format and have had no problems.In the future I would recommend bying only top quality discs as it seems a dodgy one was responsible.
Jun 29, 2008 | LG Televison & Video
Format dvd rw on eh57
...go to:-
function menu
to others
set-up
format disc
make sure you have a disc inserted first
Mar 16, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Recording to Dvd-rw
yes u hav eto use dvd +r disk ok try that 1st please thx nick
Feb 04, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD Burning doesn't work..no Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
Jan 22, 2008 | LG RH-4820 DVD Recorder
I can't see the dvds into any dvd player
Most DVD players can't play DVD-R or DVD-RW unless it's finalized (if you record to DVD+RW, it may work ok, but fewer DVD players work right with RW format discs).
Obviously, you need to ensure you are actually writing to the DVD (eg, will they play back on the camcorder). You should see if there's a menu for finalizing the DVDs, that might do it. There are occasionally problems with finalizing discs on some of these DVD camcorders... these discs may not be readable on any DVD player, but might still work in a PC.
The other problem is that some camcoders record in DVD-VR format, which is a special "easily edited" format for DVD camcorders only... regular DVD players don't usually support this (well, some new ones might... this is one of those "evolving standard" issues). You'll probably need a PC to read the disc, edit, convert to a conventional DVD, etc. if you're using this format.
Jan 02, 2008 | Samsung SC-DC164 DVD Camcorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
