Question about HP Office Equipment & Supplies
I have C4200 All-in-One printer. I installed a new color catridge. I printed align sheet, put it on glass, clicked color button. But when I try to make a copy, all I get is another alignment sheet.
  • tankesley Dec 05, 2008
    There is a OK button. It says use it, but nothing happens. I push on that OK button very hard.
  • 386 Answers
The alignment procedure is usually required after replacing an ink cartridge and you haven't yet completed or paid attention to the instructions it provides to fully complete it. Once completed it will return to normal operation.
Posted on Dec 05, 2008
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
May 26, 2015 | Canon MX340 AllInOne InkJet Printer
I bought a new colored catridge for my hp photosmart C4680 printer and installed it. After the installation the printer requested for alignment test which was done but to my greatest surprise after the...
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
Try Printing Again. I hope I was able to solve your problem. :)
Feb 04, 2011 | Office Equipment & Supplies
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
HP 6000 Won't print with yellow cartridge
Try this :
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Regards
Soumajit
Mar 12, 2010 | HP Officejet 6500 Wireless All-in-One...
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Black ink not printing or very light or split. Have installed new ink cartridges. Getting some color and headings or seals. But mostly Blank!
HI
Usually when you install new cartridges,the printer print an alignment sheet.
in case if the printer isn't printing the colors okay,
you can try cleaning the cartridges by going to the printer drivers,
goto the control panel--->printers and faxes--->rt click the printer icon and goto properties,under properties there should be an option for either maintenance or service this device button,when you click it ,it gives an option for aligning the cartridges,
you can also goto the printing preferences and it allows you to adjust the color
there is an option to clean ink cartridges
Jul 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cannot align print cartidge on HP PSC 1315
i have the same problem. i think mine centers around the fact that i refuse to spend the money to buy a color cartridge. i believe the alignment sheet must be in full color.
i did find a very strange solution to preventing the alignment page from printing, but i haven't tried it yet. http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Alignment-Page-HP-PSC1315-prints-every-time-printer-is-turned-on/m-p/224243
not a solution, but it might help...
Dec 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
I have C4200 All-in-One printer.I install new color cartridge, printed align sheet, put it on glass, hit color button. I'm still stuck; this is second question today. There is small window which says click...
Are you sure that there is not an "OK" button and you don't push the actual screen? I am guessing you have to find an "OK" button. I don't think that machine has a touch screen interface. I hope this helps.
Dec 05, 2008 | Office Equipment & Supplies
Alignment message
to fix this problem place this alignment sheet on the scanner glass as if u were copying somthing n just press the scan button .the power light will blink few times n then stop.which means alignment is complete n u hve fixed ur problem. rate this solution as fixya n encourage us to solve more n more problem in future. thanks bye
May 23, 2008 | HP PSC 1410 All-In-One InkJet Printer
Alignment problem
I want to start my office working with the HP F380 DeskJet....
Apr 30, 2008 | HP DeskJet F380 All-In-One Printer
43 people viewed this question
Seeker5211
Seeker5211
