Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater pro 110
Will run for awhile and shut off, start to puff first. I did the following:
1 adjusted pressure to 5#
2 checked and cleaned fuel filter
3 checked for air leaks
4 cleaned photo cell lens
It has strong ignition and it will run pretty reliably without the top on it, soon as i replace top it will start to puff
Thank you for any consideration
  • aalimoman Dec 07, 2008
    I have simple spark plug ignition, older unit that has worked great for years. The running great without the top is a mystery to me. Will ckeck for cleanness of fuel.
  • 10,515 Answers
Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?
Without this critical information about all this technician can do is guess.
My best guess at this time would be either water in the fuel or a restricted fuel filter.
As stated above, I was only taking a wild guess to a solution based on the information provided by you. If the filter does not cure the problem then answer the question that I asked you to answer previously.
Again, here's the question "Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?"
Here's why I asked the question- Spark plug heaters are simple to work on and simple to troubleshoot. The solution that I posted could probably solve your problem.
On the other hand, if your heater has Hot Surface Ignitor technology, then there is a computer on board and you must troubleshoot to determine whether the problem is fuel related or electronics related.
Don't just throw parts at the heater, hoping for a fix. Troubleshoot it, then throw the parts.
OK. If your heater has a circuit board, then it is an HSI type heater.
Again, did you check for water in the fuel. You never said. Simply shine a flashlight in the tank- look for water droplets rolling around on the bottom.
In a hypothetical situation here is what happens. The heater is running good. Then a droplet of water passes through the nozzle. A momentary flameout condition. A big puff of smoke & unburnt fuel. The flame perpetuates itself, but the flame has been extinguished by the water. The photocell sees the lack of flame and directs the board to shut the heater down. The heater has done its job. For safety reasons it can't just continue to pump fuel into a hot combustion chamber.
Go back to basics and check for water in the fuel before you check the board. You may just get out of this do-it-yourself project for FREE. No parts required.
From DESA's tech bulletin to test the board
"Remove fuse cover and check fuse
(70,000 to 200,000 Btu models only). If
fuse is blown replace it with a GMA-10
fuse. Disconnect motor red and white
wires from control. With Ignitor wires disconnected,
attach voltmeter leads to the
ignitor terminals (labeled IGNITOR). Use
the 0 to 200 V.A.C. scale. Plug power cord
into a grounded 120V/60 Hz outlet. Meter
should read 120V(rms) for approximately
10 seconds. If voltage reads 0 or stays at
120 for more than 10 seconds, the control
is defective and should be replaced.
Posted on Dec 05, 2008
I have a reddy heater pro 110 the igniter glows an fan runs for 5 seconds then shuts down
Check the pressure switch and check flame sensor might need cleaning
Oct 27, 2016 | Reddy Heating & Cooling
My heater keeps shutting down. Just put fuel in. Lights and runs about 5 seconds
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 12, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
It runs but it puffs smoke every 3 - 5 seconds.
I am not real familiar with the Mr Heater units, although I have been around Reddy Heaters for well over 30 years. The principal is the same, after all, Mr heater is a foreign knock-off of the Reddy Heater.
Check, in this order:
1. shine a flashlight in the tank- look for water droplets rolling around on the bottom.
2. check the fuel filter for restriction. A blocked filter will cause starvation.
3. with soapy water check for air leaks from the air pump to the nozzle. An air leak will cause reduced fuel delivery.
4. check the pump pressure, bring up to factory specs.
5. If you have turned the adjustment screw, move #5 up to #1.
6. check or replace the nozzle.
7. If the fuel delivery system checks out OK then you have an electronics problem, and I’ve been told that Mr Heater parts are rare and hard to come by.
Dec 05, 2008 | Mr. Heater MH175KT Open Flame Utility
Nov 01, 2008 | Heating & Cooling
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
65 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
