I can't get my EUR symbol to work. It used to work.
  • 903 Answers
What combination of keys do you press to get the € sign?
I don't know if it is of any help but I press CTRL and ALT to get the euro symbol or just the Alt Gr key on it own.
Posted on Dec 05, 2008
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
How can I change my Toshiba e-studio 282 language to English
08-220 User interface Language displayed at power-ON
ALL EUR: 0 UC: 0 JPN: 5 <0-6> SYS 0:
08-221 User interface Language selection in UI data at Web power ON ALL EUR: 0 UC: 0 JPN: 5 <0-6>
Nov 17, 2015 | Toshiba Office Equipment & Supplies
I have canon ir 5800cn error 014 please any help
There is service bulletin that says:
Measures against noise, E014, and faulty fixing caused by coming off of fixing roller
The fixing roller comes off, leading to noise, E014, and faulty fixing.
Because the fixing spacer [2] does not rotate while the fixing roller [3] is rotating, the retaining ring [1] becomes
detached due to frictional resistance with the fixing spacer, and the fixing roller comes off as a result.
<Factory Measures>
A projection (P-2 [1]) is added to the fixing spacer. When attaching the fixing spacer, fit the projection in a
groove (P-3 [2]) of the fixing roller shaft so that the fixing spacer will rotate together with the fixing roller and
frictional resistance between the fixing spacer and the retaining ring will be eliminated. Therefore, the retaining
ring is prevented from becoming detached.
Service Work:
Replace the fixing spacer with the new-type fixing spacer when the foregoing symptom has occurred in the
To prevent occurrence of the symptom, check the shape of the fixing spacer when replacing the fixing roller,
and replace with the new-type fixing spacer if the previous-type fixing spacer is attached.
<Point to note on attaching the fixing spacer>
Fit the projection (P-2 [1]) in the groove (P-3 [2]) of the fixing roller shaft to attach the fixing spacer.
Affected Machines:
iR C6800 EUR 230V JKH01022 and later
iR C6800N EUR 230V JKP02113 and later
iR C5800 EUR 230V KEN00106 and later
iR C5800N EUR 230V KES00135 and later
This is factory error, and I think that you must call service and have it fixed under warranty.
Hope that helped
Jul 01, 2010 | Canon Office Equipment & Supplies
Installed the webcam worked fine now it won't work.. microphone is working not camera.
Please uninstall the webcam drivers and go to the below link and download/install the latest version of the drivers/software.,crid=68,crid2=1764
That should fix the issue.
Thank you for using fixya.
Mar 25, 2010 | Labtec Logitech 1200 Webcam
Hello, anyone there? I got this message, I have not made any purchase. I lost my password. what can I do? Dec. 28, 2009 12:55:42 EST Transaction ID: 08L723428F954771Y Hello adekemi amusan, Your payment is...
If you have forgotten your e-mail address to PayPal click here: Forgot e-mail address
If you have forgotten your Password to PayPal click here: Forgot password
This should help you get into your PayPal account. PayPal allows you to reverse any transactions so if any money is missing you can claim it back.
I suggest you change your password to your PayPal account as this looks like there might be suspicious activity happening on your account.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
Dec 28, 2009 | PayPal Computers & Internet
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
