Question about GE Ultrasonic 2.1 Subwoofer Computer Speakers
Computer speaker problem
I have a GE Ultrasonix 2.1 Subwoofer Computer speakers, I have hooked them up correctly to my computer sound card etc..but no sound coming out of them..It has to be something in the settings but I just cant figure out what!! Please help.
Thanks
  • Anonymous Dec 06, 2008
    I did that, and thats not the problem.
  • 104 Answers
Make sure the cable connected to INPUT directly connected to your sound card on GREEN plugin
Best Luck!
Posted on Dec 06, 2008
  • Vanbiak Thanga
    Vanbiak Thanga Dec 06, 2008
    1. to make sure your woofer is working: touch the pin that you plugin into computer and observe the sound. I mean it should make a sound each time you touch by your finger (like duup duup dupp)
    2. YOu can check your sound driver is working fine,
    To do that go to All Program > Accessory > Entertainment > Volume Control
    If it says like there is no hardware then you need to reinstall the driver
     Best luck!
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
Cant get my ultrasonix 2.0 speakers to work?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 06, 2011 | GE ULTRASONIC PRO 2.0 Computer Speakers
Hissing from computer speakers and they are new
Hello
A hissing sound indicates the speaker amplifier has no input from the computer sound card, check to make sure the speakers are hooked up to the correct port for audio out to the speaker input, the Audio output to the speaker is the GREEN mini RCA jack on the back of the computer.
Dec 30, 2010 | Bose Companion 2 Series II Multimedia...
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
What is the voltage for the GE Ultrasonix 2.1 Computer Speakers - 98903
THE WALL TRANSFORMER STEPA DOWN VOLTAGE FROM 120 VOLTS AC TO 12 VOLTS AC @800 MILLIAMPS
Jan 01, 2010 | GE Ultrasonic 2.1 Subwoofer Computer...
I can't get sound out of my computer
first of all try plugging the speakers pin into the Green socket at the back of the cpu,make sure u have hooked up the Subwoofer and the speakers correctly.If that doesn't help try installing PC audio driver again,u must be having with u.If u dont then let me know.
Jun 01, 2009 | Ozaki DT-500 3-Piece Speaker System...
Speaker hook up
Shari,
It is my hope that I can help. This applies to the type of sound card on your PC.
- If you have a 2-channel sound card: Select 2 on the source selector switch on the subwoofer. Connect the green plug from the audio input cable to tyhe front jack on your PC sound card. With this input setting, your speakers will upmix the 4-channel signal and create a center signal for your speakers.
- If you have a 4-channel sound card: Select '4' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
- If you have a '6'-channel sound card: Select '5-1' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
Your sound card is located on the back of your PC Tower.
Good luck
Jun 24, 2008 | Logitech Z-5300 Computer Speakers
Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Feb 28, 2008 | HP JBL Platinum Computer Speakers
Internal Monitor speakers
Have you plugged its connection to your sound card on the pc? Check the connection again. it will help you.
Dec 12, 2007 | Dell Powered Subwoofer Set A425 Computer...
168 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
