Question about HP LaserJet P3005n Printer
Need help installing the firmware for an HP LJ p3005n. I have the download, and the printer is locally connected *USB*
    Problem Solver:
  • 7 Answers
David,
As per the instructions from HP for windows systems:
If the device is shared on the network, then the following command can be issued from a command prompt: copy /b FILENAME \\SHARENAME\PRINTERNAME
where FILENAME is the name of the .RFU file,SHARENAME is the name of the machine, from which the printer is being shared, and PRINTERNAME is the printer's share name.
If the device is attached locally, then the .RFU file can be sent directly to the printer with a COPY command from a command prompt or DOS window:
copy /b FILENAME PORTNAME
where FILENAME is the name of the .RFU file and PORTNAME is the name of the appropriate device port (such as LPT1).
The following can be set on the computer to help address a timeout message that may occur during an update:
From a command prompt or DOS window type the following command and press the enter key:
Mode lpt1:,,p
If the device is attached to a parallel port other than LPT1, then substitute the proper LPT port number in the MODE command. Once this command has been set the file can then be copied to the printer with the above mentioned COPY command.
NOTE: When the upgrade process has completed the LaserJet will reboot. Once the printer is back online, print a Configuration Page and verify that the new firmware has been installed.
Chris
Alkaline Water
Posted on Dec 05, 2008
Hp laserjet p2055dn blank display
Similiar Blank Display solution from HP web site:
HP LaserJet P3005 Printer Series - Blank Display
ISSUE: Printer has a blank display.
SOLUTION:
Check if the printer is connected directly into a wall outlet. If not directly connected, power off the printer and connect directly to wall outlet.
Disconnect any local or network connection from any device and keep the printer connected with the power cord cable.
Power cycle the printer. If the issue persists, continue with step 4. If the printer powers up to READY, perform the following steps:
Print a configuration page and check the firmware version. If the printer does not have the latest firmware version, upgrade the printers firmware. Click here to see the latest firmware available for your printer at www.hp.com/go/support . Select Download driver and software (and firmware) and type in the product name or select the product from the product category list.
When the firmware upgrade is completed, power cycle the printer and print a configuration page again and check firmware date code, (it should change to the latest version) then power cycle the printer again.
If the printer powers up to READY, plug the local or network cable back in and print a Windows test page by printing from any application.
If the issue persists, continue with step 4 below.
Remove any additional memory DIMM installed (usually the LaserJet P3005N, DN and X come with a 32 MB memory DIMM installed), and any Internal EIO card or internal hard disk installed and then power cycle. If the issue persists, continue with the next step.
Perform a cold reset:
Turn the device off.
Turn the device on. When the memory count begins, press and hold the check button. Continue holding down the check button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds
After the message SELECT LANGUAGE appears on the display, press the arrow up or arrow down buttons until COLD RESET is highlighted.
Press the check button. The device performs a cold reset and then continues its power-on sequence.
If the issue persists, continue with the remaining steps.
If the printer powers up to READY, test the printer functionality by printing internal pages. Plug the local or network connection in and test the printer from the workstation.
If the issue persists without any internal device installed, the printer will require service.
Contact HP support.
Click here for information on contacting HP support at welcome.hp.com/country/us/en/wwcontact_us.html.
HP LaserJet P3005 Printer Series Blank Display
Apr 09, 2016 | HP Office Equipment & Supplies
ERROR CODE 49.4CO2
49.XXXX errors are commonly firmware problems.
Go to www.hp.com/support/LJP3005.
Click Download Drivers and
Software. Check for the latest firmware
image version at the bottom of the page.
If this firmware image is newer than the
one installed on the device and the
device can receive a firmware update,
download the newer firmware upgrade
Mar 22, 2012 | HP LaserJet P3005n Printer
Hp laserjet p3005n 55.04.92 dc controller error
I need help,my printer are hp lj 3035,the error is 55.04.92-DC CONTROLLER ERROR,how to fix this erroer?
Feb 21, 2012 | HP Hewlett Packard LaserJet P3005n Printer
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from hp.com, version 4.060.7 or higher. The firmware can be downloaded from hp at "hp.com/go/support" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
EFFECTIVE DATES
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
How to ip configure hp laserjet p3005n printer pls.....
If you had the printer installation CD start the installation again and you will be prompt during the installation if you want wireless/or usb connection.If you don't had the CD you need to download a driver at LINK.
Nov 04, 2010 | HP LaserJet P3005n Printer
When printing envelopes the printer suddenly prints fact sheet
have you updated the firmware on your printer? hp has a firmware update utility down load for it that just might help you with your problem. iu fixed a simular problem by using the download
Jun 03, 2010 | HP LaserJet 1320 Printer
Wrong firmware installed in HP LJ 3050
I am very sorry to have to be the bear of bad news. Usually doing a failed firmware update (or wrong firmware version) you have to return to factory or have a local computer printer shop that deals in HP printers repair this firmware mixup. There is sometimes a firmware recovery mode that can help however You would have to contact HP and ask them how to get into firmware recovery mode.
Sorry hope this helps answer your quesiton.
Steven.
Apr 22, 2010 | Office Equipment & Supplies
I now have 2 HP LJ P3005n printers within the past 3 days that have stopped working. 1st error code on printer #1 is = 49.4C22 and 49.4C02 and the 2nd printer is now displaying error code = 49.4C02. What...
The codes indicate firmware errors (possibly a failure of the formatter board, but more likely firmware). Up-to-date firmware is available for download at www.hp.com/support/LJP3005. Read the installation instructions for the firmware update. If you have ANY doubt AT ALL about your ability to successfully update the firmware, pay a shop to do it for you. A failed firmware update may not be recoverable, and the formatter board is rather costly.
Oct 20, 2009 | HP LaserJet P3005n Printer
Installation problem of hp lj 3005d
Mkae sure you download the correct drivers from www.hp.com . The cd that comes with the unit usually only has windows XP drivers on it.
Nov 20, 2008 | HP LaserJet P3005n Printer
Install hp laser jet p2015
Please find below the link to download the driver.
I hope that the printer is connected via USB. If yes, please do not connect the USB cable before running the software. The software shall prompt you to connect the printer. Once prompted, please connect the USB cable and make sure the printer is powered on.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=LJ+P2015
- Nikhil
Nov 04, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P3005n Printer Logo
312 people viewed this question
Ben Johnson
