Question about E-Machines eMachines Desktop PC
Eurovox reboot how do you use the software to re boot my eurovox 1000sl
  • 43 Answers
Pop in the cd then restart pc then format hard drive then reinstall windows
Posted on Dec 13, 2008
Compaq presario wont start up
Several things could cause this. First try eliminating a few potentials sources of the problem --unplug external devices from the computer like external hard drives, usb sticks, printers, external speakers, etc. and see if you can boot the computer normally. If you can boot normally, try rebooting into safe mode and then running chkdsk. You may have to tap F10 repeatedly during rebooting to get to option such as safe mode. Allow chkdsk to complete its run; that takes considerable patience. IF you need to know how to run chkdisk, you can look that up in the F1 help screen while in safe mode. Uninstall whatever software you installed just before the crash. Reboot and allow normal booting. BUT BACKUP your critical information immediately if you get a good boot!
IF that does not fix the problem, you might have to look into using the recovery partition. That will likely allow a return to factory defaults, either with an erasure of your data or not, depending upon which option you decide upon. If all is erased, you may have to reinstall a considerable amount of software and reactivate windows via the internet. How do you get to the recovery partition? That is probably an option popping up when you hit F10. "R" for recovery.
Feb 11, 2015 | HP Compaq Presario SR1503wm PC Desktop
Tip
How to uninstall deep freeze
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you
can press Crtl-Alt-Shift-F6. You should now see a password dialog.
2. Enter your password and click OK. If you have not yet entered a password you should be
able to click OK without entering anything. You should now see a dialog with boot options.
3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze to this machine. By
default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for
versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
4. The software should uninstall and reboot the machine. When the machine reboots, Deep
Freeze should be uninstalled.
on Mar 15, 2010 | Computers & Internet
My computer keeps rebooting
Does it Boot or is it stuck in a boot loop cycle? Have you done ANY hardware or software, new OS?, updates/upgrades lately? Memory? Put in a new CMOS battery. Try reseating Memory Mods. Are the Fans, heatsink, vents clean? Open the BIOS setup, check Clock, set if necessary, Disable Auto Reboot. Remove ALL Media DVD,CD,USB devices, Printer cable, ect., Will it boot to Safe Mode? Take a look : http://searchenterprisedesktop.techtarget.com/Steps-for-solving-the-reboot-loop-problem May be a bad HDD? Remove and test, replace if necessary.
Feb 15, 2013 | HP Pavilion Elite M9060N PC Desktop
Instead of my home screen when I have logged in I get a black screen and white curser :s help
If you have a Windows CD or DVD run Windows Recovery Console
Steps to do this
1.Boot from CD (change boot order accesing BIOS: tap F1,F2,F10 or delete key after rebooting)
2.Choose R to run Recovery Console
3.Type 1
4.Enter your admin password
5.Type: CHKDSK -r
6.Done
Also, If you dont have a CD, reboot and tap F8 to run in Safe Mode: Uninstall any software that may cause your system to malfuntion then reboot
Hope this help
Nov 19, 2010 | Computers & Internet
Samihullah
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Mar 15, 2010 | Sony VAIO PCV-W600G PC Desktop
MY SCREEN DISPLAYS THIS, REBOOT AND SELECT PROPER BOOT DEVICE:
hi
the problem wont be solved by restoring you r computer.......... check cables
Jan 15, 2009 | Computers & Internet
ECS G31T-M keeps rebooting problem system ECS G31T-M M/B Intel Video COMBO.. Intel Core 2 Duo E8400 Processor 3.0GHz (3.0GHz x 2) CPU 6MB L2 Cache 1333MHz FSB .. MassCool LGA 775 CPU Cooler /...
what was the software.... and if you can... boot into safe mode.... tap f8 when it starts it's boot up and remove the offending program....
Robert
Sep 06, 2008 | EliteGroup Computers & Internet
I have an older Acer computer and need to reformat the hard drive and install new software. I can not get into set up mode to change the boot order. Can you help
to change the boot order insert the os disc reboot the computer
and keep tapping on esc key continously ull get the boot order window ...
May 19, 2008 | Acer Computers & Internet
Eurovox
eurovox 2008 works fine on all free chanals but iv lost all pay chanals sky moves ect
Apr 13, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
69 people viewed this question
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
