Question about Dell Inspiron 6000 Notebook
Dell inspiron 6000 will not let me sign into windows at the sign in screen for windows.
When I re-boot the computer, windows opens and takes me to the sign in screen where my name and icon are located. I click on my name and it prompts me to enter a password. I have no password and never have. Once hit enter another prompt screen comes up saying to contact the administrator. The current screen that I am on is part of the diagnostics check. There is an error detected on the hard drive, the test that reports an error is the DST Short Status Test and the grey prompt box in the middle of the screen claims that, "No Diagnostic Utility Partition found. To run diagnostics, insert your Dell "Drivers and Utilities" CD, then select OK to restart the system and boot off the CD. OK or cancel." I do not have this CD. Is there another way to correct the problem?
    Genius:
  • 1,605 Answers
The diagnostic check is because the system didn't shut down correctly.
are your the administrator for the laptop?
The administrator password is the password that you put in when you install the operating system, if you did not give it a password, then the administrator password is blank. (Windows Vista requires a password).
you can try "Adminstrator" as password.
the choice is press F8 immediately after the BIOS start up. select "last good configuration" and press enter.
go to the following link and download the utilities if you need.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_6000&os=WW1&osl=en&catid=&impid=
Posted on Dec 05, 2008
Recover passwords
Here's How:
  1. Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
    Tip: See How to Boot From a CD, DVD, or BD Disc or How to Boot From a USB Device if you've never booted from portable media before or if you're having trouble doing so.
    Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free. See How to Create a Windows 7 System Repair Disc for a tutorial.
  2. After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
    Tip: Don't see this screen or do you see your typical Windows 7 logon screen? Chances are good that your computer booted from your hard drive (like it normally does) instead of from the disc or flash drive you inserted, which is what you want. See the appropriate link in the tip from Step 1 above for help.
  3. Click on the Repair your computer link.
    Note: If you booted with a system repair disc instead of a Windows 7 installation disc or flash drive, you won't see this link. Just move on to Step 4 below.
  4. Wait while your Windows 7 installation is located on your computer.
  5. Once your installation is found, take note of the drive letter found in the Location column. Most Windows 7 installations will show D: but yours may be different.
    Note: While in Windows, the drive that Windows 7 is installed on is probably labeled as the C: drive. However, when booting from Windows 7 install or repair media, a hidden drive is available that usually isn't. This drive is given the first available drive letter, probably C:, leaving the next available drive letter, probably D:, for the next drive - the one with Windows 7 installed on it.
  6. Select Windows 7 from the Operating System list and then click the Next button.
  7. From System Recovery Options, choose Command Prompt.
  8. With Command Prompt now open, execute the following two commands, in this order:
    copy d:\windows\system32\utilman.exe d:\ copy d:\windows\system32\cmd.exe d:\windows\system32\utilman.exe To the Overwrite question after executing the second command, answer with Yes.
    Important: If the drive that Windows 7 is installed on in your computer is not D: (Step 5), be sure to change all instances of d: in the commands above with the correct drive letter.
  9. Remove the disc or flash drive and then restart your computer.
    You can close the Command Prompt window and click Restart but it's also okay in this situation to restart using your computer's restart button.
  10. Once the Windows 7 logon screen appears, locate the little icon on the bottom-left of the screen that looks like a pie with a square around it and then click it!
    Tip: If your normal Windows 7 logon screen did not show up, check to see that you removed the disc or flash drive you inserted in Step 1. Your computer may continue to boot from this device instead of your hard drive if you don't remove it.
  11. Now that Command Prompt is open, execute the net user command as shown, replacingmyusername with whatever your user name is and mypassword with whatever new password you'd like to use:
    net user myusername mypassword So, for example, I would do something like this:
    net user Tim 1lov3blueberrie$ Tip: If your username has spaces, put double quotes around it when executing net user, as in net user "Tim Fisher" 1lov3blueberrie$.
  12. Close the Command Prompt window.
  13. Login with your new password!
  14. Create a Windows 7 Password Reset Disk! This is the Microsoft-approved, proactive step you should have done a long time ago. All you need is a blank flash drive or floppy disk and you'll never need to worry about forgetting your Windows 7 password again.
  15. While not required, it would probably be wise to undo the hack that makes this work. If you don't, you won't have access to accessibiily features from the Windows 7 login screen.
    To reverse the changes you've made, repeat Steps 1 through 7 above. When you have access to Command Prompt again, execute the following:
    copy d:\utilman.exe d:\windows\system32\utilman.exe Confirm the overwrite and then restart your computer.
    Important: Undoing this hack will have no impact on your new password. Whatever password you set in Step 11 is still valid.
Nov 11, 2013 | Computers & Internet
Forgot password
Oct 14, 2013 | Computers & Internet
Wireless network
Troubleshoot a Compaq Wireless Network Card
step 1
Open the Compaq's "Start" menu and type "Device Manager" in the "Search" box. Click the "Device Manager" icon.
step 2
Scroll down to the "Network Adapters" heading and click the plus sign to expand the list of attached network adapters. Right-click the name of your computer's wireless network card and choose "Uninstall." Follow the uninstall prompts on the screen.
step 3
Close the "Device Manager" window and return to the "Start" menu. Click "Restart" and wait for the operating system to boot up again. Follow the "Found New Hardware" prompt that loads on the screen to reinstall the network card.
step 4
Return to the "Device Manager" window and right-click the network card's entry again. Choose "Update Device Driver." Follow the prompts to install the latest driver.
step 5
Check the left side of your Compaq computer if you are using a laptop to see if it has a wireless network switch. Push the switch over to the "On" setting if it is set to "Off."
step 6
Open the "Start" menu and click "Network." Select the "Network and Sharing Center" icon at the top of the window.
step 7
Click the red "X" icon to have Windows automatically search for the problem. Follow the prompts to diagnose and resolve the network connection issue.
step 8
Double-click the networking icon in the system tray at the lower, right corner of the screen and click the name of the network you need to connect to if you are using Windows 7. In Windows Vista, instead click "Connect To" in the "Start" menu and click the name of the network.
Setup home Wireless Network
Dec 07, 2010 | Compaq Presario 700 470024-192 Notebook
My computer does not recognize hardware. FYI: Machine hums when I insert a disk.
These are the steps to resolve the issue for the cd/dvd icon missing in the My computer.
Step 1: Please perform manual registry set up by following the below steps:
Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries.
Follow these steps to backup registry:
1. Click Start, select Run. In the "Open" field type REGEDIT
2. Click OK and click "File" in the menu bar
3. Click "Export" from the drop down menu this will open a new box
4. Click the down arrow beside "Save In" and select "Local Disk (C:)"
5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All"
6. Click Save.
Now make the following changes in registry:
1. Click Start and click Run(XP) or type Click Start and type regedit in search then hit enter(vista, Windows 7).
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor.
Step 2: Please uninstall the CD/DVD drive form Device Manager :
1. Click Start and select Control Panel.
2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
4. Click the Hardware tab and then click the Device Manager button.
5. Click the plus (+) sign next to the DVD/CD-ROM drives .
6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.
7. Repeat step 6 until all entries under the device category are deleted.
8. Restart the computer.
After the notebook is restarted it automatically detects the drive and the drivers are installed.
Regards,
Shami
Nov 22, 2010 | HP DVD1040e DVD-RAM Burner
My computer will not recognize the dvd1260i burner
6. Click Save.
method.
Regards,
Shami
Oct 31, 2010 | HP DVD1260i DVDRAM Burner
I cant see my dvd/cd drive in"my computer" wndow, but it is visible in "device manager"
6. Click Save.
method.
Regards,
Shami
Oct 28, 2010 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
TSST Corp CDRW/DVD TSL462D ATA Device (code 10) will not start up.
Please perform the below steps to fix the issue:
6. Click Save.
method.
Regards,
Shami
Oct 04, 2010 | Computers & Internet
Forgot password
Steps :
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message “Press any key to boot from cd” appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer’s startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
When you log in sign in to name with password that was forgotten and change to one that is known.
Sep 27, 2009 | Toshiba Satellite L305D-S5934 Notebook
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
Computer problem
that is your DOS prompt
Try typing at the black cursor (chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
If that does not work
Shut down PC
F8 on boot get back to Advanced boot option
SAFE MODE WITH NETWORKING
Sign in as ADMIN or Owner
say yes to get to Desktop
Once you get to the Desktop
(Windows XP)
Start>RUN>CMD (This will be the command prompt window}
(chkdsk /r <ENTER> <Y> <ENTER> Restart the PC)
(Vista)
Start>Start Search>cmd>(above) Right click on CMD>Left click(RUN ADMIN) (This will be the command prompt window)(chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
Jan 23, 2009 | Intel D845GVSR Motherboard
Dell Inspiron 6000 Notebook Logo
329 people viewed this question
Alun Cox
