Question about New World E70DOa Electric Double Oven
Element / burner / hob is overheating on an electric oven
Three of the rings are burning at the highest heat and not responding to being placed on a low setting.
is this a thermostat problem? how easy would it be to remedy?
many thanks
  • robjames_22 Dec 06, 2008
    high five for getting back to me.
    it has a glass top, so im guessing unscrewing the panel would give me access...what does the regulator look like / located?
  • robjames_22 Dec 09, 2008
    is this what im after..?
    http://www.espares.co.uk/part/cookers-an...
    cheers again for all the help
    top site!
  • New World Master
  • 3,463 Answers
If three of the rings are not responding to adjustment, then I would say yes, you have faulty regulators;It is a fairly straightfoirward job to replace if you know how to access the controls
Posted on Dec 05, 2008
  • Barry Coates
    Barry Coates Dec 06, 2008
    Hi.
    The regulators are the ones with the dials on,
    which control your plate temps.
    One for each hotplate.
    You may have remove the side panels to access the regulators
  • Barry Coates
    Barry Coates Dec 10, 2008
    You must quote the exact model number of the appliance, serial number, and an exact description of the parts you require
    If you are not sure what you want and live in the u/k, let me have the details, and I will see if I can sort out the partnumbers for you..
Have Ck90g232 model,electric oven has no heat,the fan still works but not the light. All other ovens and hobs are functioning,is this an element issue and will a professional have to fix the problem?
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Nov 15, 2017 | Ovens Ovens
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
Why does oven shut off seconds after starting
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
Jun 08, 2014 | Whirlpool RBS275PD Electric Single Oven
Zanussi oven keeps cutting out
The reason for my free advice is GOD is good!
May 07, 2014 | Zanussi ZBF360X Electric Single Oven
Hi, 3 of the 4 oven hobs have failed to work on the 720ef. only 1 of them heats up now. when you turn the knob of the failed hobs only 1 out of the 3 makes the click noise but still doesnt heat up,...
Normally the 720ef is the oven, the hob is a separate unit and in my case is a STOVES 600G gas unit. Your unit may have a built on hob but the handbook for the 720ef does not detail this. In my case the hob ID is on the lower right hand side of the unit.
I think you will find that the elements may have failed but you will need to identify the hob to ensure correct replacements. Normally the element rating is on the base of the element. The handbook will tell you how to take the thing to pieces. It is possible that the hob element controls have failed but unlikely for all three or it may be a combination of both parts. I think you may have to contact an electrician to test everything to sort this out.
Mar 08, 2011 | Stoves 720EF Electric Double Oven
I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
Hi, I cannot get the oven element or the back left burner to heat up.I found a blown 15 amp fuse blown in the oven and replaced it but still no power to the two elements. I took out the oven element to...
I take it when you mention burners you are refering to electrical hot plates?
If you have tested with 110V --even nthough it should be 240V then I can assume that the hob is working.
Possible cause is the regulator.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Ovens
Element / burner / hob are overheating on electric oven
It would appear that you have faulty temperature regulators, which you will have to replace, for three to go together is unusual, have you spilt something on the top, because liquid could have got inside the control panel.
Please leave feedback.
Thanks.
Dec 05, 2008 | New World E70DOa Electric Double Oven
New World E70DOa Electric Double Oven Logo
667 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
