Faxing with Dell printer 968
I 'm connected to a wall telephone jack with a splitter---one end wiith a filter is connected to my phone other goes into my modem supplied by Verizon DSL (model 7500).
I have the owner's manual,but I'm having problems sending faxes.
Also I assume that to receive faxes, the person sending can use my telephone number as my fax number.
Albert M Garofalo
  • 414 Answers
Firstly yes your telephone number is used as your Fax number.
Your phone line connections sound ok, so the problem must be with your fax machine.If it's a combined Fax/Printer make sure you select Fax mode.
Posted on Dec 05, 2008
I have fax problem in my multi-function panasonic printer machine, all the power and rest functions are working other than fax, I am not getting the line dial tone when pressing monitor even the faxline is...
See Page 72 of the User Manual available here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Multifunction-Printers/How-To-Guides/model.KX-FLB801.H#ts
I cannot hear a dial tone.
The telephone line cord is connected to the [EXT] jack on the unit. Connect to the [LINE] jack (page 21).
L If you use a splitter/coupler to connect the unit, remove the splitter/coupler and connect the unit to the wall jack directly. If the unit operates properly, check the splitter/coupler.
L Disconnect the unit from the telephone line and connect a known working telephone. If the working telephone operates properly, contact our service personnel to have the unit repaired. If the
working telephone does not operate properly, contact your telephone company.
L The power cord or telephone line cord is not connected. Check the connections.
L If you connected the unit through a computer modem, connect the unit directly to a telephone line jack.
I cannot make calls. L The dialing mode setting may be wrong. Change the setting (feature #120 on page 22).
The unit does not ring. L The ringer volume is turned OFF. Adjust it (page 23).
Hope this is helpful. ;)
Dec 10, 2010 | Panasonic KX-FLB801 All-In-One Laser...
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Fax gets a phone line error. I switched from 1 line to another. I used a single line splitter but it still will not fax. What to do?
Hi, it seems you got a connection problem. Here are some tips to check it:
1. Make sure the phone line in the wall is working. There should be a dial tone if you connect a regular phone device in that.
2. Check if the telephone cable that you're using is in good condition.
3. Telephone cable from the wall/splitter must be plugged in to the Line port behind the printer.
4. Make sure that it's the correct fax number assigned in the printer.
5. If all is ok but still having the error, try plugging the printer/fax straight to the wall jack bypassing the splitter.
Hope this helps.
Mar 06, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Hooking up cables and phone line to use the Fax on the P3150
Find a telephone wall-jack.
Buy a 1-to-2 telephone-splitter -- one end plugs into the wall-jack, and the other end provides 2 telephone-jacks.
Connect your telephone to one of those 2 jacks.
Connect your All-In-One to the other of those 2 jacks.
Be sure to use a 4-wire telephone-cable, not an 8-wire network-cable.
Feb 03, 2010 | Lexmark P3150 All-In-One InkJet Printer
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
HP FAX ISSUES
Check LIU
Remove the SPLITTER
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
How do i find out what modem to use for my win
Any internal or external modem less than 10 years old will support FAX-ing through it.
Telephone wall jack <--- telephone splitter --> telephone cord <--> modem
Telephone wall jack <--- telephone splitter --> telephone-cord <--> ISDN adapter.
Dec 08, 2009 | Dell Computers & Internet
Telephone line connection
Two options:
1) Pick up a phone line splitter (Radio Shack or just about any other retailer has them) that has a plug on one side and two jacks on the other. Plug this into the phone jack where the line to your computer is connected. Plug the cord to the computer back into one jack on the splitter and plug the line to the fax machine into the other jack. (If it will physically fit into the space on the back of the computer, you can just plug the splitter into the modem connector, plug the line cord into one jack and the fax cord into the other.)
2) (Useful if the phone jack is behind furniture or just hard to get at.) Get a phone line splitter with all jacks (two on one side, on on the other). Unplug the line cord from the computer and plug it into the single jack on one side of the splitter. Then run a new line cord from one of the two jacks on the other side back to your computer. Plug the cord to the fax machine into the other jack.
Jan 27, 2009 | Dell A940 All-In-One InkJet Printer
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
Oct 12, 2008 | Canon Office Equipment & Supplies
I can't receive and send fax
The splitter the technician is referring to goes on the wall jack. One should have come with the "modem" installation package.
Take a regular telephone cord and plug one end into the splitter and the other into the line jack on the Fax/printer.
When your done you should have two phone cords connected to the splitter - one going to the "modem" and the other to the printer.
Nov 11, 2007 | Office Equipment & Supplies
214 people viewed this question
k24674
