Question about Samsung HCJ552W 55" Rear Projection Television
My TV doesnt turn on. where is ther fuse?
I am pretty sure its the fuse. or something with power. My tv stopped working as soon as i plugged it in. i had it for a while. NO leaks or anything but it just wont turn on all the sudden. Can someone tell me where the fuse is and where I can get that part? thanks.
    Sergeant:
  • 308 Answers
The fuse should be near where the line cord is attached to the power supply inside the TV. Be careful as there is a possibility of some DC voltage present from filter capacitors still holding a charge, long after the set is unplugged. If a fuse is blown and blackened, a new fuse will probably do the same when the set is plugged back in. Make sure you use the exact same rated fuse. IF the new fuse blows right away, do not repeat the process, it will only cause more damage. Good Luck.
Posted on Feb 11, 2007
SOURCE:
Can't turn on/off using either switch on front or remote. was plugged into outlet on cable set-top box. perhaps something was fried by sudden power outage.
In that case if ther is no power you better check first the power in the outlet they have.Then check the continuity of AC cord of the TV.If they are good,check the fuse,located inside at the power supply section near the AC supply voltage input.Replace same value of fuse if busted.Then try to turn on again..Try this procedure,hope will it help you..Thanks..
Aug 26, 2011 | Toshiba MD20FN3 20 in. TV/DVD Combo
POWER PROBLEMS
T.V. DOSEN'T WORK AT NO MATTER WHERE I PLUG IN THE HOUSE.
Nov 03, 2008 | Protron PLTV3250 32 in. LCD Television
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Hooked a antenna to my RCA tv because we had know cable an as soon as we did it now tv doesnt come on it is model number 20V500T
Are you sure it does not come on, or no video (black screen)? Plugging in the cable should not affect the TV turning on. The only possible way I can think of that hooking up a cable would shut down the power is if you have a ground fault. The shield of the cable should be earth ground. If your TV had a power leakage, grounding the chasis by attaching the cable might blow a fuse. This seems highly unlikely, however.
May 13, 2008 | Televison & Video
Right out of the box. doesnt work
Don't feel bad - these are cheap TV's and there are lots of problems with them. Just be glad it failed so soon that you can take it right back and get something more name brand this time.
Remember - always google the model number you are looking to buy (with either "repair" or "complaint" in the search) and you'll be less likely to buy an TV industry land mine.
Jan 24, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Tv wont turn on
The surge most likely shorted the horizontal output transistor, and with that being shorted, it causes the power supply to "sing" from the increased load it is seeing. Unfortunately, it would probably cost near $100 to repair unless you were able to do it yourself.
Dec 30, 2007 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
Samsung HCJ552W 55" Rear Projection Television Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
