Only prints once ??
Recently my copier will only print one copy and then the light goes from green to red. Power on/off goes back to green, but back to red after one more copy. Any ideas ???
Thanks, Joe
  • 1 more comment
  • Jcharlto Dec 06, 2008
    Toshiba BD-3810, there is a print key (rightmost button on the selection panel) that remains red until the copier is ready, then turns green.
    Thanks,
  • Fernan
    Fernan May 11, 2010
    please check if there is a toner,and the model of your copier
  • CheckitRight
    CheckitRight May 11, 2010
    need more info. what make and model? does it give you an error code ? what symbol lights up?
    so far it sounds to me aas if ti is reading a different type of paper than what's in the tray.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
If I remember this is a very old copier. I still beleive there is a problem 1- the size of the paper ( it could be you have Letter and it is reading Legal ) 2- a sensor, it may be getting stuck check right before the drum and in the fuser section for the sensors.
Posted on Dec 08, 2008
I have LANIER LD115 Copier/ printer can not copy and print ,red light showen on copy button,Erro shown " SC: 544" AND " CALL SERIVCES" , GREEN Light on copy indicator, red on printer light, shown up
The copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
This error can mean the:
PSU board is bad
IOB board is bad
BICU board is bad
Defective thermistor in the fuser
Defective power supply
You need to contact a local service technician to take a look at your copier.
Nov 08, 2014 | Office Equipment & Supplies
Printer
Hi
Try disconnecting printer from computer, power off and killing any print jobs in the print queue.
Then check that the printer powers on whilst un-connected to the PC, if light stays green, then the problem is related to PC interface. If the light goes red, then it's a hardware fault, maybe remove and replace cartridge, check no paper is jammed and try again.
Regards
Rob
Plain, Printed and Barcode Labels
May 09, 2012 | Office Equipment & Supplies
Prints multiple copies of job and will not shut off or stop printing
Unplug the power cord from the printer. Hold down the red "X" button. Plug the power cord back in while holding down this button. Release the button. Should see flashing red and green lights. Unplug the power cord again. Replug. Should be reset.
Apr 10, 2011 | Dell 1100 Laser Printer
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark All-in-One Printer with PictBridge
Status light goes green when power on, but then turns red and cannot print - replaced toner cartridge- not sure what the reason for the red error light is?
You have to reset your printer with a module or replace chip when you refill toner cartridges.
www.nakshatraworld.com
Jan 07, 2010 | Samsung CLP 300 Laser Printer
Prints only part of label
Fixed problem. Labels were too thin so LED was still being detected to stop progress of labels. Fixed by sticking some backing paper over the sensor and seems to be working fine.
Jun 12, 2009 | Zebra Eltron Orion LP2443 Thermal Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Re:Minolta copier EP 2151 I am trying to print a stack of documents using SDH mode (semi-automatic document handling). The SDH mode green light comes on and blinks, but the light on the "go' (print) button...
If the green light on the adf is blinking that means that there is a paper jam in the adf. I sure you know that the copier you are using is at least 10 - 15 years old. Has the adf worked recently? Are one of the adf hings broken? If so, line the adf straight on the top of the copy board glass. There is a magnet that needs to be closed to make the adf work. Try to see if there is any small piece of paper in the papeer path of the adf and use a can of air to blow out the sensors and get back to us.
Jan 14, 2009 | Canon imageRUNNER C3220 Color Copier
Only prints once ?? Toshiba BD-3810
When the toner is very low the copier is programmed to only print one copy.
Fill the toner and it should go back to normal
Dec 05, 2008 | Office Equipment & Supplies
27 people viewed this question
k24674
jasbo
jasbo
