Question about Philips Computers & Internet
Shaver doesn't cut - Philips Computers & Internet
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, there are a couple of reasons why an electric shaver would no longer cut:
  • the blades are already dull, replacement;
  • the angle of the blades have changed, replace;
  • the screen/grill cover is clogged, cleaning;
  • the blade rotation is slow, motor problem, replace;
  • the blade rotation is slow, motor spins lower and slower, battery weak, needs recharging or replacement.
Good luck and Thank you for using FixYa.
Posted on Dec 05, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    Genius:
  • 3,422 Answers
HI,
Please let me know the make and model no. of your shaver.
  • Priya darshan Dec 05, 2008
    HI,
    Determine which type of shaver you have. There are
    two main types: rotary head and foil/cutter. If the shaver doesn't cut
    like it used to, it could be the cutter or the foils may need replaced.
    It's recommended that with the foil/cutter model, the cutter and foils
    be replaced approximately every nine months. Rotary head shavers should
    have the head replaced every 2 years.
    Step2
    Charge the shaver if it's the cordless type. If you notice the speed of
    the shaver slowing down, that could be the problem. If the slowness
    persists, the battery pack may need to be replaced. If the shaver takes
    batteries, you will need to take it to a professional that specializes
    in shaver repair. The batteries are attached to foil, and it takes a
    special tool to remove them.
    Step3
    Repair a foil/cutter shaver by first unplugging the shaver (if it's the
    cord/cordless type). Next, take out either the screws or clips or
    pressing the pressure button.
    Step4
    Remove the screen, and clean it with a brush that most shavers come
    with. If the head looks corroded, purchase a new head. Remove the
    assembly unit for the blades, and clean it with canned air. Lubricate
    all areas with shaver oil lubricant. Read the owner's manual to
    determine what type of lubricant to use and what areas need
    lubrication.
    Step5
    Repair a rotary head shaver much the same way except use a clean, flat
    surface to clean all the parts. Again use lubrication as recommended by
    the manufacturer.
    Step6
    Maintain your electric shaver by cleaning once a month and replacing parts as suggested by the manufacturer.
  • Philips Master
  • 19,396 Answers
You need to replace the blades, tell us the exact model.
Brought a new cutting bar but would not cut
Most, likely, your oscillator is broken. It is the plastic piece that transfers the rotary motion of the motor to a 'back and forth' motion
Wahl DynaFlex ID Shaver Oscillator
Mar 10, 2016 | Wahl new 5-star shaver 8061
What is a foil electrical shaver?
Foil electric shaver use an oscillating motion in order to cut hairs through a foil. The blade inside positioned in line and may contain up to four rows of blades. The foil electric shavers are ideal for men who are just starting to shave or men with slow beard growth.
Feb 06, 2013 | Health & Beauty
Ref. Braun shaver (mod. 5567 -"universal"). Just changed the batteries after 20 yrs. of use. The motor is really powerful, now. The shaver, however, does not want to cut my whiskers now. It...
Based on the information you provided, it sounds like the shaver is working as it should. If the hair you are attempting to shaver is longer than 1 days growth, you will need to trim it down to stubble length for the shaver to be able to cut it properly
Jul 12, 2017 | Braun Health & Beauty
Where do I oil my Braun 4700 series shaver ? On the foil, the cutting block or where the cutting block plugs into the base area? Thank you.
With the shaver fully assembled, apply one drop to each of the two foils. Turn the shaver on and run for 5 seconds to spread the oil accross the foils
Braun shaver oil can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-accessories/braun-shaver-oil-p-465.html
Jul 20, 2011 | Braun Health & Beauty
When I turn on my Pilishave razor the blades don't turn. When I open the top, the plastic pieces the turn the blades turn, but when I close it the blades don't turn. What is wrong?
Your blades are either damaged and locking up or they are so clogged with hair that they can not turn.
I suggest that you try to clean them first. If that doesn't work you will need to change them. You will find replacements for model HQ4806 at shaveroutlet.com. See link below for product and disassembly instruction video
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
Jun 22, 2011 | Philips Philishave Micro Action HQ 4806...
The shaver is **** after using it still not smooth , it says it has holes and slots for all type of growth ( after full charge it sounds like it has not the energy to cut baby hair) for all the grand prix...
First thing, reset the outlet. That's a common thing looked over. Next (if that doesn't work) is pull out the warranty papers because if it isn't the outlet, then it's the product. If you have had it for less than a year, they should allow you to use your warranty and have them fix it.
Jun 18, 2011 | Philips HQ7300 7300 Series Shaver Electric...
I installed 3 new heads but the shaver just is not shaving off my 5 day old beard... It's battery seems fine as the motor seems to be running at normal speed. Confused Carl
Your Norelco shaver is not designed for cutting 5 days of growth. Your shaver is designed for cutting one, maybe two days of growth only. Use the trimmer on the back to cut the whiskers to a shorter stubble. Then the hairs will more effectively poke through the holes and slots in the combs allowing the blades to shave them as designed.
May 08, 2011 | Norelco SmartTouch 9160XL Electric Shaver
Computers & Internet Logo
22 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
