Question about Dell Inspiron 1501 Notebook
Error message on my broadcom
Whenever my computer loads up I get a pxe-e61 and pxe-m0f error
  • Desktopsbyduck-Computers
    WHAT TYPE OF LAPTOP IS IT?.ARE YOU RUNNING WINDOWS? WHICH OS? SEND INFO SO I MAY ASSIST YOU FURTHER.RICHARDM69 ALSO DO YOU HAVE AN ASUS MOTHERBOARD INSTALLED?ARE YOU BOOTING TO PXE DESKTOP/ENVIROMENT?
  • 3,940 Answers
PXE errors (Also known as Pixie errors) occurs when the system bios setup is configured to attempt to boot to the network card (an option used in some networks to load system images)
You can boot to the system setup (F2 at Dell screen) and make sure the HDD is 1st in the boot sequence and *** if there is a setting for the network card to turn off PXE (Usually they the following options (ON, OFF, ON W/PXE, select the ON option)
If the system is failing to boot to the hard drive at all, this can be a sympton of a failing hard disk drive. You can try and confirm this by booting to the HDD diagnostic on the F12 on time boot menu or boot to the Dell Resource CD and run diags from it. If the HDD fails diagnostics, it definitely needs to be replaced. If the diags pass, it is no guarantee that the drive is good though, just an indication that no fault was found.
Posted on Dec 06, 2008
First ther was a error message, then the pc make nothing.
If you have a spike in the power, unplug, remove the battery, then hold the power button down for 1min or 60s, to release any built up shock power. then insert the battery, (no power cord) push and hold power button for 1 -2 - 3 s. release and see what happens.. now what OS is installed on the HDD. and check the BIOS to see how the boot sequence is set... seems your error show you set to boot to NetWork not HDD
May 28, 2014 | Acer Aspire 5500 5570-2609 Laptop
I have a fiujitsu hard drive in my acer aspire 5315 my keyboard has no keys just some rubber tips and when i turn on its says broadcom UNDI PXE-2.1 v10. 0. 9 copyright yada yada and then it says: PXE-E61:...
The keyboard needs replacing. Replacement keyboard for your laptop maybe available from this WEB site.
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Dec 18, 2012 | Computers & Internet
PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM Operating System not found Acer Travelmate 5720G
This error is a result of your computer not finding the operating system. This is usually the case when the hard drive has failed. You will need to take the computer to a technician to replace the hard drive and have windows reinstalled.
Mar 06, 2011 | Computers & Internet
My laptop isnt working.as soon as u turn it on a black screen comes up and the message display says PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM!! how can i fix it
It goes to a network boot rather than booting straight to the HDD. restart your computer and press f2 immediatley. you are now on the BIOS page. check if your hard drive is detected and if not call Lenovo to have it replaced/repaired. if it is detected, after the PXE error, your computer should boot up just fine.
Jun 05, 2010 | Lenovo 3000 G530 Notebook
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Can't boot up without a boot disk
Your computer has been configured to try to "boot" by loading the Operating System from a network-connected "boot-server". Since you're _NOT_ likely to have such a "boot-server" in your home-network, the error-messages that you get are what are _expected_ when your computer is _NOT_ connected via the Ethernet cable to a 'PXE' (Pre-Boot Execution Environment) boot-server.
Enter BIOS-setup, and disable the "boot from network" option.
Mar 01, 2010 | Computers & Internet
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Dell Inspiron 1501 Notebook Logo
208 people viewed this question
Alun Cox
