Question about Samsung ( TS-H492A/WBEH) (TS-H492A/WBEH) CD-RW/DVD-ROM (Combo) Burner
My burner have a mind of it's own
My drive just open and close at will and will not read any cd/dvd neither audio nothing. I tried uninstalled it and let ep reinstall it at boot up but the problem continue. I can see it in my computer and device manager says it is working ok. What shall I do next???
  • Uncle_sam Nov 09, 2007
    I have two cd-rw sh-r522c samsung and they both have the same problem , the door wont open and sometimes if it opens and you try to close it , it opens on its own , and if i forced a cd entrance it will read it.
    I tried to clean the lenses , micro switches in the nechanics , updated firmware and nothing was solved.
    Can you help me ? Thanks
  • venkatesh Dec 09, 2007
    i have a problem with my writer (not reading & writing).
  • 624 Answers
Hi Shycshaw, If it was working and then stopped without any major changes the chances are pretty good that the drive is beyond economic repair, especially in light of the symptoms you are describing. Having said that have you tried: - cleaning your read/write heads using a commercial cleaner yet? I?d be skeptical that a dirty read/write head could cause what you?ve been observing but it?s worth a try. -- open the case and reseat the drive power and data cables. Also check and reseat the cables on the other drive (if any) connected to the same IDE channel (cable) as well as where the cable connects to your motherboard. Loose or improperly connected connects could cause intermittent faults like you are observing as well. Generally optical drives do wear out, some more quickly than others. For users with high usage of CD/DVD drive I usually install both an R/W drive and a DVD/CD ROM drive in the same PC. I instruct the users to only use the ROM drive for playing which saves wear and tear on the more expensive R/W drive. If you use your optical drive a lot this might be a good tactic for you as well. Good luck and please don?t forget to rate this posting. Hi Shycshaw, If it was working and then stopped without any major changes the chances are pretty good that the drive is beyond economic repair, especially in light of the symptoms you are describing. Having said that have you tried: - cleaning your read/write heads using a commercial cleaner yet? I?d be skeptical that a dirty read/write head could cause what you?ve been observing but it?s worth a try. -- open the case and reseat the drive power and data cables. Also check and reseat the cables on the other drive (if any) connected to the same IDE channel (cable) as well as where the cable connects to your motherboard. Loose or improperly connected connects could cause intermittent faults like you are observing as well. Generally optical drives do wear out, some more quickly than others. For users with high usage of CD/DVD drive I usually install both an R/W drive and a DVD/CD ROM drive in the same PC. I instruct the users to only use the ROM drive for playing which saves wear and tear on the more expensive R/W drive. If you use your optical drive a lot this might be a good tactic for you as well. Good luck and please don?t forget to rate this posting.
Posted on Feb 11, 2007
I have a Dell Inspiron 9400 laptop with a sony cdrw/dvd cr835e. The drive reads cds without a hitch. It will not read dvds. When I put a dvd into the drive, the drive attempts to read it quite a few...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Sep 18, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
AsusCB-5216A cann't read dvd
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 12, 2011 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Just installed Sony AD-5260S DVD burner in HP machine running Windows XP Professional. Can read and write CDs and read DVDs but can't write DVDs.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 11, 2011 | Sony Computers & Internet
My samsung dvd writer can't read cd
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 23, 2011 | Samsung SH-S223C 22X DVD Writer SATA Black...
My DVD-ROM is not reading any cd's but it is reading dvd very well.On inserting cd green light flashes then nothing happens.please help me asap.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
dont forget to vote
Feb 23, 2011 | Lite On (DH-52C2P-04) CD-RW/DVD-ROM Combo...
When i put a disc into my burner it shows there is nothing on there i have changed the burner for a brand new one but still got the same problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
dont forget to vote
Feb 11, 2011 | LG GH22LS50 DVD-RAM Burner
CD/DVD drive problem
See if the Drive Reads in My Computer. See if you can see the contents of the CD. Try to run or play the data.
If not... you may need to uninstall the CD driver and let it reload again. The way to do that is to Rt Click My Computer | Letf Click Properties | go to Device Manager | go to and open DVD - CD Rom Drive Folder | Rt Click the Device and unistall. Total Shut Down Reboot after taken out the Drive in the system. Start up and let it completely finish. Shut down again... restart with drive back in. Hopfully it will redetect and work.
If not again... Bad Drive ?
Dec 31, 2009 | Computers & Internet
LITEON DVD/CD-RW CAN READ DVD BUT NOT AUDIO/DATA CD.
I would suggest cleaning the drive with a cleaning dvd, $19.99 at most retailers. Or you can open up your computer and verify all connections to the drive are good, disconnect and re-connect to be sure. Hope this helps.
Sep 15, 2007 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Combo drive CD not reading, but DVD ok
it may have dual laser and one that reads cd's is faulty, but try uninstalling the dvd drive first then re installing it to see if it cures it, if not the drive will need replacing. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
Mar 30, 2007 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
My dvd combo does not read dvd
There are separate lasers for CD reading, and for DVD reading. This is why it is possible to have a drive that reads only CDs but not DVDs, or the other way around. And your particular combo unit seems to have a lot of these problems. Since the drive doesn't work it's almost definitely a problem with the drive itself (I'm assuming that there is nothing wrong with the discs you tried to read). If that drive is still covered by a warranty period, send it back for repairs. Otherwise, I can't see the harm in trying to tinker with it yourself as the DVD portion of it is dead anyways. Ummm, on a side note...CompUSA is going out of business and they are selling things cheap. I got a DVD lightscribe burner for $40...booyah!
Mar 26, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Samsung ( TS-H492A/WBEH) (TS-H492A/WBEH) CD-RW/DVD-ROM (Combo) Burner Logo
48 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
