Question about Toshiba RD-XS25 DVD Recorder/HDD Recorder
Unable to finalise disc after recording
I recorded a dvd from a vcr but it will not play on my other dvd player (sony) I have been told that I may have to mfinalise the disc but I have no manual to get these instructions from. CAN YOU PLEASE HELP?
    Sergeant:
    Champion:
  • 201 Answers
Check the net download CD Roller very good program that finalises DVD cd etc wth recover options very cool! program
Posted on Dec 05, 2008
How can I show my DVD-R(Memorex) on my televison?
I assume you mean that your current DVD player won't play this DVD?
There are 3 reasons that it won't play. One that the disc is faulty and therefore won't play on any machine. Two that the disc has a scratch or has marks on it. You can look at ways to clean the disc on-line!
3 That it was not finalised on the machine that it was recorded on. If you current player is a + machine it won't play the disc if it is unfinalised. You will need to use the old machine to finalise the disc or another "-" disc recorder to do it - if it will accept the disc! Otherwise if the old DVD recorder is no longer with you, then your only hope to save the disc is to find another model of your old recorder to do it on. If it was a common model someone might let you finalise the disc!
Feb 21, 2013 | Panasonic Original Pansonic Tv Vcr Dvd...
Why doesn't a -dvd recorded on sansui not playback on another dvd player
Sounds like the disc needs to be finalised to close the session...put the disc in and look for this in the disc option menu's
Feb 11, 2012 | Sansui VRDVD4005 DVD Player/VCR
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Funai VCR/DVD recorder DVR 2737. My -R discs record ok but during finalising I get disc error - cannot record on this disc Error code E22. Can you help?
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Oct 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When I record a dvd on my vr375 it will not play on my DSE dvd player .I am useing a Sony -RW DVD
before the disc will play on other players, you need to "finalise" the disc. Finalisation ensures compatibility with other devices. Go into the "Setup" menu, and look for "Disk Manager", there will be a finalise option. select the option, and after approx. 3mins the disc will play on other players.
Jul 18, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
DVDs from DVR don't play on any other DVD player
yes when you have finished the recording and preferably when the disc is full the disc must be finalised to be compatible with other players but be aware if you finalise a disc you cannot record on it anymore
Mar 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Emerson EWR20V5 DVD Recorder/ VCR Combo
didn't realize had to finalise the disc after recording.
May 26, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Playing disc
any disc recorded on the liteon must be "FINALISED" before it will play on other machines.use "disctools" in the liteon menu to tdo this.
Sep 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Toshiba RD-XS25 DVD Recorder/HDD Recorder Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
