Question about Microwave Ovens
GE JVM1870SK03 won't heat food, hums and puts out a burning smell
I have a GE JVM1870SK03 Under cabinet microwave. Everything seems like it is working (lights, panel, turntable), but does not heat. It makes a humming noise and it puts out a burned smell (no visible smoke) but it doesn't blow the fuse. I have never repaired anything electronic...is this something that a novice could fix, is it very expensive to get repaired - basically, should I repair the unit or replace it...not sure what to do.
  • Microwave Ovens Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more and is more complicated to replace.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it needs a new magnetron, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If you want to contact GE about having an authorized servicer look at it, or have them send you a magnetron, GE Customer Service is here.
Posted on Dec 07, 2008
JVM16331BB005 over the range microwave oven will not heat everything else works ok
That is a sign the magnetron has shorted and is the most expensive part to replace.
Apr 28, 2012 | GE Microwave Ovens
MMV5100AAW Microwave hums and smells burnt , will not heat food , everything else works fine
If you have that funny burning smell in the microwave oven This is sure sign the magnetron has failed, and must be replaced.
Mar 21, 2012 | Maytag MMV5165 Microwave Oven
Have ge profile spacesaver xl sensor. will not heat strange buzzing sound and burning smell. clock, light, vent still work
This is most likely a defective magnetron, especially with the burning smell. There are two other parts that can be a problem, the high voltage capacitor and diode, all three work together to heat food. If the magnetron is the culprit, probably cheaper to replace the microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave no longer heats food and it smells as if something is burning. Everything else on the microwave works. Is this a common problem and how can I fix it?
Its your Magnatron tube, thats what makes the microwaves and heats the food. The part will cost you more than a new micro. The new model that replaced yours is a JVM1540 and you can get them for 179.00
Jan 17, 2011 | GE JVM1440 Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE Model #JE1640WB - Makes noise when
Magnetron is done. This part heats the food. GE microwaves tend to have them stop working quite frequently. They basically make up the majority of the cost of the microwave, so instead of replacing the magnetron, you would be better off getting a new microwave.
Benjamin
Jul 15, 2009 | General Electric Microwave Oven
Spilled some water on top ge micro wave while cleaning cabinets
YOUR BLOWER FAN MAY HAVE QUIT AND WITHOUT THE AIR CIRCULATION IT OVERHEATIND THE INTERNALS OF IT AND UNFORTUNATELY THIS UNIT WILL COST YOU MORE TO FIX THAN GETTING A NEW ONE. RED HOT IS VERY BAD ON A MICROWAVE
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
1,267 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
