Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Touchpad doesn't work when starting from standby
Dell inspiron 6000 laptop, when I restart my computer from standby my touch pad doesn't work. I must cold boot every time then touch pad works again. Cannot find a driver download on Dell web site maybe you could help. Thanks Ed Baldwin
    Genius:
  • Dell Master
  • 1,102 Answers
Set your standby setting to never
Posted on Feb 15, 2009
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
I want to deactivate my touch pad on my dell inspiron 1525 laptop. Please advise how
If you do not see a Touchpad icon in your systray(lower right), go to:
Start/Control Panel/System
On the left choose "Device Manager".
Select "Mice and other pointing devices" and highlight "Dell Touchpad"
Either right click and "Uninstall" or click the uninstall icon at the top.
Restart your machine and it will automatically update the driver from Dell which will put the Touchpad icon back in the system tray.
Click on this icon and go to "Device Select"
Check the "Disable Touchpad/Pointing stick when external USB mouse id present.
Sep 24, 2009 | Dell F3534 Touchpad
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Touchpad not working properly
The touchpad is on its way out sorry to say
Aug 27, 2009 | Dell F3534 Touchpad
Tap to click does not work dell inspiron 1501
Tap to click is the feature of the touchpad driver. Uninstall any existing touchpad drivers and then restart the computer.
Go to www.support.dell.com enter the computer service tag and get the drivers for the touchpad from there. Also update the BIOS of your computer to the most recent version. In most cases a part replacement is not needed and the issue should be fixed.
Rate if useful.
Aug 10, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1501 Touchpad locked up
Check the system setup F2 at start, and ensure the touchpad is enabled, next try an external mouse, see if it works.
If and external mouse works, the touch pad has failed and a new palmrest is needed.
Jul 29, 2009 | Computers & Internet
My Dell Inspiron 6000 notebook computer curser "jumps around"
I frequently have the same thing when using a Dell laptop. The problem MAY be with the touch pad. Without noticing it, my thumb touches the pad and away goes the cursor!
So try this: Open the control panel and go to mouse. Look at the top for Touchpad. There is a setting in there for sensitivity. Reduce the setting so that you need to apply more pressure on the touch pad to move the cursor. Test it a few times to make sure it is still functional before closing the control panel. Then try typing something in a word processor and see if it is any better.
Good luck, and please let me know if this helps.
~ Spoem
Mar 30, 2009 | Dell Inspiron 6000 Notebook
Touchpad
Please install touch pad drivers from www.support.dell.com by entering the service tag... that shouls automatically enable the touch pad.
Sep 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Aug 28, 2008 | Computers & Internet
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
310 people viewed this question
Alun Cox
