Question about Dishwashers
GE Quietpower 3, dishwasher dirty
My dishwasher, gets disgustingly dirty. I get black mold and pink algie in the diswaher its self. The door and all the bottom of the dishwasher always needs cleaning. The wheel for the basket even get gunkey. I have had numerous dishwashers before in the same spot and none have ever had a algie or mold build up. It is about 1.5 years old and I have the repair man here many times. He said he has never seen anything like this and replace just about everything that he could on the machine. I spend more time cleaning the dishwasher than it does dishes! Help, and thank you.
SOURCE: Dishwasher leaves a fine black sludge
I work in a hospital and have seen this problem with our scope washers (a very sophisticated dishwasher with lots of safety features) and it turned out to be a faulty pump motor.  Some pumps have black ceramic magnet in them and if it cracks it will breakdown and mix in with wash water creating a black smudge on everything with bits. Just as you described.  Unfortunately, I have never taken a part a dishwasher motor so I don't know if it's the same type of motor.
Posted on Oct 11, 2007
  • 114 Answers
SOURCE: ge potscrubber 640 dishwasher
You probably have a restricted water inlet valve. It is not allowing the proper rate of flow for the allotted time, therefore not giving enough water to create the proper velocity to reach the top rack.
Posted on Feb 19, 2008
  • 409 Answers
SOURCE: Brown sticky spots
sounds like you have an oil leak from the motor/pump assembly. this should be covered under warranty by the mfg. have a technician replace the sump assembly.
Posted on Sep 13, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
  • 60 Answers
SOURCE: Calcium buildup in dishwasher-receiving low ampage
Have you tried cleaning with vinegar? Start the washer and let it get to the start of the wash cycle. Open it up and scoop out about a gallon of water from the bottom. Pour in a gallon of vinegar and let it finish the wash. May have to repeat a few times. This should get it. To keep it clean, add a few vitamin C tablets in with your detergent every few washes.
Posted on May 21, 2010
GE GLDT690TBB Fully Integrated Dishwasher with 7 Wash Cycles Including SaniWash and SpeedWash, Nylon Racks, Stainless Steel Interior, Countdown Display and QuietPower 56 Quiet PackaBlack- Recent Questions, Troubleshooting & Support
Oct 07, 2015 | GE GLDT690TWW Fully Integrated Dishwasher...
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
Jul 29, 2011 | Maytag Dishwasher
GE Quietpower 3 Dishwasher does not stop running when door is open. I'm really tired of getting splashed in the face because I forgot a plate. *head desk*
Haha. Sorry but happened to me once. The door switch has gone bad. Get a new door switch and you'll be fine.
Jan 31, 2010 | Dishwashers
I myself have done a wash with bleach only instead of detergent...No clothes just one cycle with bleach. A cup added directly to tub and also fill bleach dispenser.. this took care of my mold in door gasket
Dec 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
My GE Quietpower 3 has blinking lights, goes through a short cycle and shuts off. How can I either reset or fix? I've already flipped the breakers.
To re- set can take up to 90 second's depending on the cycle, the door has to remain locked or it will not re-set. Our's had not been installed correctly, it had to be closed very hard to get it to lock, it was doing the same thing as your's. Hope this help's. That beeping is annpying.
Aug 13, 2009 | General Electric Adora GHDA670N Built-in...
No water in dishwasher
check the water valve it could be bad and not be letting water into the unit...let me know and I will further assist you.
May 13, 2009 | GE Dishwashers
QuietPower 3, water seeps into unit,fills the base once per week.
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Dec 14, 2008 | GE 24 in. Profile PDW7800 Built-in...
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Dishwashers Logo
426 people viewed this question
Top Dishwashers Experts
