Question about RCA F27649 27" TV
Screen not centerd
In-laws bought television 3 months ago. They just brought to my attention that the screen is not centered--cannot see full left side and bottom.
    President:
  • 1,284 Answers
If it is a RCA F27649 then it has what they call a bonded yoke, meaning the only adjustments to shift the picture horizontal or vertical are electronic adjustments via the service menu.
Posted on Feb 12, 2007
SOURCE:
Samsung ST550 Camera Touch Screen Unresponsive Had the camera for 18 months and over the last 3 months the left hand side of the touch screen has stopped working. The camera's lived in a protective...
I had this problem about my touch screen same with you. The touch screen on left hand has stopped working. I had it for 20 months. I live in Thailand. I think that it is the big problem for ST550. I've brought it to Samsung Customer Center. and they've introduced me to change the new touch screen. It is about USD50.00. I am bored. I used it a little bit.
Jul 16, 2011 | Samsung DualView TL225 / ST550 Digital...
My Mitsubishi WD-62725 dlp powers up , no blinking lights, the screen on all inputs is blue with streaking horiz lines and snowball in center screen. Menu works, tuner seams to work but screen goes black...
Call Encompass Parts 1800-638-3328 or look them up online they list your TV as well as Service Manual and Keep in Mind just because Light Engine was replaced 3 months ago does not mean it cannot be same Problem so if you have any warranty on it replace it again!
Nov 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blue Haze in middle of screen progressively getting larger
This one is easy. WHen this happened to me, I simply called GE extended warranty service up and bought an extended warranty. I waited 30 days and called them up with my problem. A repair man showed up a few days later with the 1200 dollar light engine and installed it and left. Then I called GE up and cancelled the warranty. Total cost?: 48 bucks
May 30, 2009 | Hitachi 50V720 Television
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Showing
ok you have convegence problem. i suggest you read "fl231 problems under tips in tricks of my profile. this could be a simple easy inexpensive repair. i believe you can get to it under my profile. if that dont help then let me know i will help you further
Sep 20, 2008 | RCA HD52W59 HDTV Projection Television
Philips 9p5034c101 rear projection.chassis#ptv 835
Just replace the two STK392-110 Convergence ICs and that will correct the convergence. The small pic if its centerd in the center of the screen is usually caused by the opto-couplers being bad
May 18, 2008 | Philips 9P5034C 50" Rear Projection...
Little white dots on the screen
dirty lens, dirty mirrors, warped light guides, spider webs and mini-UFOs that fly across the inside can cause what you described.
but 6 months is pretty early for a cleaning but possible.
May 16, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Problem with display
Hello
If you only bought it 2 months ago it will be under warranty
You should send it back to be serviced as it sounds like a faulty LCD and it will need to be replaced
Dec 25, 2007 | Sony Ericsson W850i Cellular Phone
RCA F27649 27" TV Logo
75 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
