LG DVD drive stopped reading DVD's
My LG DVD Drive has stopped reading DVD's completely. Earlier it some times used to read DVD's with auto run but now that also stopped. It never read CD's .when i try to brows DVD's through mycomputer it shows empty drive as if dvd is not present in the drive.
    Novelist:
    Champion:
  • 233 Answers
Try re-installing the drivers. If that doesn't help get a new drive. Optical drives are one of the first things to break in a computer. Of course make sure everything is connected properly.
Posted on Dec 28, 2008
Burn DVD but not read
Use a 3rd party DVD burning software, it can burn a complete DVD easily.
Dec 12, 2012 | LG GH20NS15 20x DVD RW Drive with...
LG dvd/cd-RW drive not reasd dvd bt read cd .help
i found when u burn too many cd,s on a dvd burner it stops burning dvd,s is this why ? buy a new one if its still new get ur money bk buy a different model : )
Apr 27, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Hi, I am using LG GSA-H55N. Few days back it was reading DVD's properly but suddenly stopped playing DVD's. It is showing the drive but on clicking the drive letter it is showing a blank page. Please help
Hadi-23-Jan-2009
Hello, I am using LG GSA-H55N. Few days back it was reading DVD's properly but suddenly stopped playing DVD's. It is showing the drive but on clicking the drive letter it is showing a blank page. Please help
Jan 14, 2009 | LG GSA-H55N DVD-RAM Burner
No disks being read in the LG drive.
Also try uninstalling and reinstalling in device manager and check the cables to make sure they are properly seated.
Dec 26, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Sony DVD RW DRU-710A
sounds like the DVD drive is in need of some repair there if its making some odd sounds and miss reading CDs and DVDs also make sure connections are good behind the drive
Mar 02, 2017 | Sony DRU-710A DVD±RW Dual Layer...
Hl-dt-st dvd-ram gsa-h55n LG DVD drive not reading DVDs recently
It would appear that the problem you are experiencing could be due to 1 of the 2 following items;
1. Re-install the software driver & software that came with the drive.
2. Set the region /Country that the drive will be working in or the language that you understand (USA=Region 1). It should be noted here that this option has a limitation of being changed up to 5 times but once it hits the fifth time the drive will be permanently set to that region and can not be changed anymore for the rest of the drives lifetime!!! The drive will usually work fine once it has been set (the default from the factory is ZERO (NOT SET)) and that may work fine for a while but it should be set to a region and it will understand all previously burnt /movie dvds that have this option set in the data already.
Good Luck!
Rich Lilja
Sep 03, 2008 | LG SecurDisc 20x Internal Double-Layer DVD...
DVD/RW drive
hi, it seems ur DVD drive is little bit aged. or sometime it happens that, after an overburn it stops reading cd. any way it is possible to repair the drive in either case, or go for a new one.
Jun 22, 2008 | Computers & Internet
LG GSA H55L DVD READ PROBLEM
It is possible there is a bottle neck in your system stopping it from allowing the dvd to play.
The DVD drive is only one part of it. There is the cable to the motherboard, CPU load, memory load, Video card being used etc.
If the drive is connected to another DVD/CD drive on the same cable, try unplugging it first and see if it improves. Also if it is running on the same cable as a hard drive, your main hard drive in particular, then try to get it onto it's own cable.
Check the software running it is not in software mode using it's particular config section within the program as well. If your video card supports hardware mode for video playback, then that will reduce system power being used by the CPU and the memory systems.
Apr 20, 2008 | LG (GDR8164B) Internal DVD Drive
I am having a LG DVD writer GSA-4167B currently stops reading or writing disks after few runs
as with all writers eventually they fault at the lens and it gets out of line and cannot read discs, you can try the usual thing of checking LG for any firmware updates, but first:- Go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays.
Jun 19, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
