Question about Whirlpool GU2400XTP Built-in Dishwasher
Water left in the dishwasher after washing is finished
Whirlpool dishwasher
Serial # F9 33 26989
Model # DU7600SX-3
Stock # DU7600S
Motor 5.3 amps
Heater 67 amps
The dishwasher will not always go through the complete wash and rinse cycle. There are times that it will go through the complete cycle and there is clear soapy water left in the bottom. We had the lines and the shut off valves to the sink replace today.
Do you think that the pump needs replacing and/or the control dial?
We have lived in this house for 15 years and never replaced the dishwasher so we're not sure how old it is. It does a fine job when it works. Do you think it needs to be replaced or fixed?
Glenna Atkinson
  • glatkin Dec 10, 2008
    Didn't get a solution
    I'm buying a new one
    The old one was taken right after I put it outside on the side of the road
    Someone else will figure it out.
  • dadpirrman Dec 10, 2008
    dishwasher will not drain
Thank you...I already solved the problem.
Posted on Dec 07, 2008
Whirlpool DU1055xtss3 It washes but it seems that the drain pump doesn't stop even if no more water inside. End up pushing cancel Twice or pump just continues. Don't know if full wash cycle finished
Paul Lvesque, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Paul Lvesque), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool Washing Machines
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Turn dishwasher on . the water loads in and then goes into wash cycle, it does it's wash cycle then drains and will not load clean water for rinse cycle it just hums a and then quits, then tries again and...
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool GU2300XTS 24 in Builtin...
Dishwasher fills but no pressure during wash, middle and upper sprayer are not moving. I cleaned trap and lines in tub - no improvement. Is pump bad, how to test? Is this worth fixing?
What I would Do :
1st I would start your dishwasher and let it fill with water and when it stoped filling, I would open the door to see how much water it filled in the tub. ((( if you don't have enough water you will not get the correct pressure )))
If We have enough water we then close the dishwasher door and resume.
you have 2 motors in the bottom of your dishwasher, The drain pump motor and the Wash motor. They should be differen sounds.
We want to know if your wash motor is coming on.
If your wash motor is coming on then I will listen to see if I here water coming out of the spray arm. (( somtimes you can here the swish of the water hiting the door ))
If you do not here the water then I would open the door and position all spray arms the same way and close the door for a min and reopen to see if i have any movment.
If you do not have any movement and did here the motor run then your impellor might be broken or cloged or bound. you will only really find out by taking it apart. you could buy the hole pump & motor Kit. but you can save money by finding out what is the cause.
You can see a breakdown of a similar model here
I was unable to get your model to come up and you should check the machine model number so you have it to get the correct parts. Look at the pump & motor section and you will see how this pump is broken down.
If you don't think your getting the proper water amount, just open the dishwasher door and pour 5 or 6 glasses in and close the door for the wash cycle and listen for a differance.
Jan 08, 2010 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool disher
Run diagnostic by pressing Normal, heated dry, normal, heated dry, normal heated dry. a total of 3 times in 15 seconds.
The dishwasher will reboot and run a test load.
Nov 15, 2009 | Dishwashers
Extremely long cycle
The drying coil that is broken also heats the water during the wash and rinsing phase. Right now it is waiting for the water to heat up, that's why it's pausing. Replace broken heater, they are relatively cheap and can be gotten at repair clinic.com.
Feb 16, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwasher problem
1) wash motor seized (remove object)
2) loose motor connection (plug in)
3) start capacitor unpluged or failure (replace capacitor or plug in)
4) motor winding open (replace motor)
5) faulty wash pump circuit (replace control )
let me know and I can help you narrow it down..
Jul 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore Dishwasher does not wash
Stew, Im not really sure what model you have 665, 587, 363 or what. If it's a 665, it sounds like the wash motor is not getting power. Remove the toe panel and look at the start capacitor. See if one of the wires came off during the reinstallation. Should be on the left side of the wash motor. If one of the wires is off, wash motor won't run. If that's ok, check the main harness to the motor. Catriver
Sep 17, 2007 | Kenmore 15129 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
190 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
