Question about GE GSH25KGRWW Side by Side Refrigerator
Side by side stopped working but clicling noises every second two.
2005 GE Side by Side stopped working today. It Is getting power. Circuit board is making a clicking noise about every second or two. Also clicking by what I believe is the compressor(Metal obect at bottom mounted w/ rubber dampners.). Actual clicking happening at Electrical componet attached to compressor. Disconnected wires from module attached to compressor and checked connections. Every time the clicking happens the fan attached to motor moves slightly. Seems like the refrigerator clicking is happening to get compressor or motor started but it is just not starting. Looked for a reset switch or blown fuse but couldn't find anything. No other noises happening. Did all basic checks, adjusted temp controls, checked breakers, Hit compressor to get it started :) nothing worked. Any help would be greatly appreciated
    President:
  • 878 Answers
Read, this model posted has a main board in back that controls the refer. Your problem sounds like the overload and relay on the compressor but you need to do a test to verify. On the main board in back there is a blue harness, 3 pronged, that is marked line, defr and comp. Lower left hand corner. You need to get a jumper wire with alligator clips and with the plug out, jump line to comp. Now plug it back in, this will send 120V directly to the compressor. See if it starts. If not and it does it clicking thing, chances are it's the overload and relay, or the compressor itself. You have five years warranty on the compresser. If it starts, it's the board it's the board giving you the problem. This of course is for the GSH model posted...Catriver..post back.
Posted on Feb 11, 2007
  • gmilo2 Dec 01, 2010
    The manual says that the clicking can go on for up to five minutes when it is trying to restart. I know it doesn't address the issue of the refrigerator stopping working in the first place, but should try resetting by unplugging and then seeing if it will start. Then again, this was posted 4 years ago........
    Problem Solver:
  • 8 Answers
I fixed my motherboard.
Board WKKT Model 0158-00-04
Board GEA Part 200D4854G013
I replaced both 47uF x 400V capacitors - one of them was bulged. The bad one was open, and the other still had it's nominal value.
I tryed to make the refrigerator work, to no avail.
After a careful inspection, i replaced both 470uF x 25V capacitor (c29 and c30, i guess - near the 7805 regulator). Both had around 0.5% of their original value, and i belive it was the source of the problem.
Everytime the processor tried to start the relay, the power level dropped and the motherboard "rebooted"... and thus the cycles and clicks from the relay.
The refrigerator got back to life!
There was a recall by GE on November, 2006.
Call GE at 18003861215, option 3. Mention the recall and maybe it's still valid a free replacement.
Posted on Dec 17, 2013
SOURCE:
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
My refidgerator & freezer stopped getting cold. It is running but no cold air on both sides. (It was making a clicking noise that was coming from the circuit board on the back of the unit) but that has...
Replace the mother board. (it's the board you heard clicking) The only thing you hear running are fans. Check your model and serial number with your parts supplier, as you may be able to get the board free. (only certain models / serial numbers qualify)
Nov 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The circuit board is making a clicking noise... I
Sounds like you have a GE side by side, replace the mother board. Common problem. Once you replace then check to make sure the evap fan is running and condenser fan are working.
Sep 30, 2009 | Refrigerators
My ge side by side refrigerator has stop coolin on both sides
The clicking you hear is most likely the compressor trying to cycle. It sounds to me like you are low on refrigerant. Most are thermo. protected and will not run on low coolant. Frigerators DO NOT make cold, they absorb heat from inside the box and expell it out the back. Most common cause of refrigerant loss is a leak, usually near the compressor. Hope I Helped
Mar 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Jul 26, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Open Questions:
GE GSH25KGRWW Side by Side Refrigerator Logo
547 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
