Installing a R232-HBF REGULATOR -What's up with this screen/vent deal? Will mosture affect it?- thank's
  • johnnymonnky Dec 05, 2008
    CAN THIS REGULATOR BE INSTALLED VERTICALLY SO I DO HAVE TO BUILD A COVER OVER IT?
  • 1,420 Answers
Most all regulators require a differential in pressure to work. To get a differential, you need to have gas pressure on one side of the diaphragm and atmosphere pressure on the other side. If you have high moisture, you can either effect the differential pressure, cause a freezing condition in the regulator in cooler weather or subject the regulator to premature failure due to corrosion. You did not explain if this is going to be used in a high moisture area or not. Can the regulator be vented to a low moisture area?
Posted on Dec 05, 2008
Do you have a manual for OMRON HBF-302
Try Googling (Omron)(HBF-302)(manual) without parens.
May 25, 2017 | Omron Health & Beauty
Need user manual for Omron HBF-302
If you haven't already tried it, Google (Omron) (HBF-302)(manual) without parens, of course.
Mar 11, 2016 | Omron Health & Beauty
1996 cherokee Country Wagon
Hi Debra: I sugges to check this procedure...
Fig. 1: TBI fuel pressure regulator
  1. Remove the throttle body assembly from the vehicle as outlined in this section.
WARNING To prevent spring pressure release, hold the regulator housing against the throttle body while removing the mounting screws.
  1. Remove the three retaining screws that hold the pressure regulator to the fuel body.
  2. Disassemble the pressure regulator assembly. Note the location of the components for reassembly. Discard the gasket.
To install:
  1. Install a new gasket and the regulator assembly. Tighten the three retaining screws.
  2. Install the throttle body assembly as outlined in this section.
WARNING The pressure regulator diaphragm MUST be installed with the vent hole aligned with the vent holes in the throttle body and regulator housing!
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 21, 2011 | Jeep Cars & Trucks
Where is the fuel pressure regulator located on a 1996 jeep grand cherokee, laredo, straight 6 cyl.?
it's under the throttle body
Fig. Fig. 1: TBI fuel pressure regulator
To install:
Oct 11, 2010 | Jeep Grand Cherokee Cars & Trucks
Hi, M fridge at times has lots of condensation around the inside top and the freezer at times has when you open it has lots of like smoke thanks jackson
you are not getting a complete defrost. and mosture is building insde / card board is soft with mosture, ck the drain and the defrost heater's and the defrost terminator . these would cause the problem hope this helps mm
Sep 24, 2010 | Amana ARB9059CS Bottom Freezer...
During mornings time the engine starts
The air flow meter housung probably has mosture in side it!
You Jet washed it right?
so it's forced water inside... then it evaparates inside (VAPOR CAN'T GET OUT AGAIN) goes back to mosture when cool and plays about with air meter's electronics! OPEN THE LID AND DRY IT OUT WITH HAIR DRYER!
then re-seal it wirh silicione!
you see simple!
Do you remember years ago when old distibuter caps had a small hole (vent) in them yes? same thing! if your ign system got wet, whwnn the engine got hot the vaper could escape though the vent so the problem did not return understand?
That's you sorted sir!...Have a good one....regards..Bruce
Mar 10, 2010 | 1994 Nissan Pathfinder
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore dryer
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
Sep 14, 2006 | Kenmore 62602 Electric Dryer
Heating & Cooling Logo
169 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
