Question about Samsung Televison & Video
I have samsung LN46A550 I get no picture but sound Please help. Thank you.
2 Suggested Answers
SOURCE: screen calibration
want to get the best picture possible out of my Philips 42PFL3603D HDTV. Any recommendation on screen settings or software to help with this?
Posted on May 27, 2008
Negative picture
If you are certain the problem is in the T-con board, you will have to repair or replace it.
Jan 14, 2014 | Samsung LN46A550 LCD TV
Samsung le32r7 tv picture light levels v low
Reverts eventually means there is some looseness some where. Please check connectors and cables between power supply- TCON, TCON- Panel and main board-TCON. If you cant do it show it to some qualified technician.
Dec 20, 2013 | Samsung LN46A550 LCD TV
Samsung LCD TV 46 inch LN46A550 colors are all messed up.
My solution to that pixelation color problem was replacement of the flat wire connected to the Tuner board and video data board,must be new and original replacement part. I clean the terminals(don't brush just spray on)with electronic contact cleaner,let it dry or blow dry with hair dryer to vaporize left over liquid on both boards.Reason these flat wire problem is due to environmental(moisture)corrosion and breakage of the folded parts of the wire. I tested the replaced part and found breaks or cut ,we call it in electronic term"open connection".
Dec 18, 2012 | Samsung LN46A550 LCD TV
Vertical lines left half of screen
You might be advised to look on EBAY for someone junking one for the parts----I do MFR. warranty work and from most makers it is nearly impossible to get replacement ribbon cables for sets....you sound smart so are aware issue could be inside the display panel as well....
Jun 09, 2012 | Samsung LN46A550 LCD TV
I have a LN46A550 flatscreen...the picture is now only in the upper left hand part of the screen. It's basically 1/6 of the screen. I have tried to pull up the PIP function on the remote and it will not...
there should be a ratio button on the remote if not its deffinitly in the main menu click on 16/9 wide screen you seem to have the veiw secound channel working on you set but were is the big picture of the current show? anyhow try that and let me know how you went
merry christmas
Dec 22, 2010 | Samsung LN46A550 LCD TV
Samsung 650 LCD picture is cut off top and bottom
select the correct tv format, check your manual
Jan 01, 2010 | Samsung LN46A550 LCD TV
When i go to turn my tv on it makes a clicking sound and i get no picture. how do i fix this?
the power supply board has died and must be replaced. call 1-800-samsung or go to samsung.com to find nearest service center.
Dec 02, 2009 | Samsung LN46A550 LCD TV
Image gets pixelated and a black screen flashes
yes its a cable box problem, find the channel you are having more problems with,press guide in the cable box remote and you will see how the box where the video is will still have the problem and the guide with channels info its going to be clean,
100% weak signal
hdtvman
Jun 22, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Screen calibration
May 26, 2008 | Televison & Video
Televison & Video Logo
Henry  Thomas
Henry Thomas
