Difference between a writable DVD of 1X8x ajaspreetarnend 1X16x.
Please,I would like to know about the difference between DVD of 8x and 16x and would it affect the recording? since this is the first time I bought it w/o reading the print.
  • 51 Answers
The only difference is that the 16x will get the job done faster.
The playback speed will be exactly the same.
Posted on Dec 05, 2008
Emachines 5240 dvdrom Can you tell me if I can fit any dvd rom into my desktop 5240 it says 8x max but items I have seen for sale are all 16 x. also can you give me the original serial no...
Hey, there's no way to give you the original serial number unless we can see it. There should be a barcode or label somewhere on the machine that has that. Sometimes its also on the bottom.
As far as the DVD Rom, it will fit any dvd, but the fastest it can write(burn) a DVD is 8x. You can use a 16x DVD just fine. The 16x on the DVD's just means thats the fastest a burner can write to that dvd. Some burners can write 16x, and others like yours burn at 8x.
Hope this helps.
Jul 16, 2011 | eMachines Computers & Internet
I want to know what type of blank dvd?
You can use any kind of writable DVD the difference is that DVD-R, are more secure and data is better protected so you have a Combo or DVD+RW Drive 8X CD/DVD Burner (Dual Layer DVD+/-R Drive) that allows you to use a double layer DVD+ R or CD + R
if it works for you don't forget to rate me
thx
May 16, 2010 | Dell Inspiron 1318 Notebook
My NEC DVD RW -3500AG will record using 8X DVD- R but not 16X can you advise
Dear friend please see your DVD top side, is there mention that DVD able to record 16X speed ? If not then you can't record that on 16X speed. Thanks.
Jan 29, 2010 | NEC ND3500 16X Double Layer DVD RW ND-3500...
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
Cd/dvd rom does not read dvd
Do you have the correct DVD? is it a DVD R DVDR- or A DVD +- and what is the speed of the DVD 4x 8x 16x it makes a difference.
Jun 19, 2009 | Acer TravelMate 2300 Notebook
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
Recording DVD-RW
Make sure the discs you are using are the same as the ones listed as compatible in the manual:
• DVD-RW ver. 1.1 / 1x / 1x to 2x, ver. 1.2 /
2x to 4x / 2x to 6x
• DVD-R ver. 2.0 /1x / 1x to 4x /
1x to 8x / 1x to 16x, ver. 2.1 / 1x to 8x / 1x
to 16x
• DVD+RW 1x to 2.4x / 1x to 4x / 3.3x to 8x
• DVD+R 1x to 2.4x / 1x to 4x / 1x to 8x / 1x
to 16x
• DVD-RAM ver. 2.0 / 2x, ver. 2.1 / 2x / 2x to
3x / 2x to 5x, ver. 2.2 / 2x / 2x to 3x / 2x to 5x
• DVD-R DL ver. 3.0 / 2x to 4x
• DVD+R DL 2.4x / 2.4x to 8x
Any brand can be used.
Jan 11, 2008 | Pioneer DVR-540HX DVD Recorder/HDD...
Cannot write cds at lower speed like 8x
  1. Try to Use Nero or Easy CD creator software for better output.....
  2. Try burning Verbatim 16x DVD+R at 16x first and then burn another of the same type at 8x. And then compare the results. Most times, burning 16x-rated DVD+R/-R media at 12x or 8x will result in fewer PIEs/PIFs.
Whether 1x is better than 8x is another issue. Personally, I prefer 8x speed for most media I use these days (rated at between 4x to 16x but mostly 8x.)
Nov 26, 2007 | Computers & Internet
16x DVD-R
Can you send me the upgrade to 8X?
Thanks Carmie
carmie@hotmail.com
Nov 02, 2007 | Sylvania SRDV495
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    49 people viewed this question
     Grubhead
    Grubhead
