Question about Intel Computers & Internet
Sound stops suddenly
While i was working on my system suddenly sound stops but while i keep my system in stand by mode then again i start it the problem gets solved but this problem is repeating again and again........plz suggest me some solution to this.............
.......i have no sound cards........
    Master:
  • 474 Answers
Alright, so wait, explain that again, It stops working when your using it, or when it goes into standby?
It starts working again after what? When you come out of standby?
When going into standby, the system goes on low power may cut the power to your speakers.
Check your Power settings.
RIGHT CLICK on DESKTOP> Select properties, Go to screen saver Tab and click on the Power button, then check all the power options such as when it goes into standby, how long till it does and adjust them to your preferences, also make sure Hibernation is turned off as well, when it goes into Hubernation, it cuts almost everything.
Give this a try and let me know,
good luck
Posted on Dec 05, 2008
Hi, H650, working fine, then erratically just stop, seems electrical problem, side stand switch were suspicious, took it off and bridged the wires, the same problem, Thx
Hi, Tamas the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Runs stops starts backfires
Engine turns off all of sudden when riding
Kawasaki Ninja 650 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Apr 01, 2017 | 2008 kawasaki Ninja 650R
Why audio stop suddenly & after restart system it start ??
Re-install the drivers for your sound card. You can download them off the laptop manufacturers website, under Support/Downloads
Aug 29, 2014 | Computers & Internet
"Can't return from standby mode" the VGA,
Did you un-installed the previous graphic driver? Quick remody:
keep pressed the power button of the cpu and press again to start the computer.
If the system freezes in the stand by mode again;
Uninstall all drivers and re-install it gain. this might solve the problem.
May 31, 2011 | Computers & Internet
Windows stop and nothing happin
hi If able to load win XP or any operating system that mean your system is booting and is in good condition. if there is issue with load of OS in normal mode then you try using last used configuration. follow this steps
1) keep press F8 when bios screen goes off until you see win xp option
2) then choose "last used configuration".
it will try to boot the system even though the system does boot properly then repair the os by booting xp dvd or cd from cd & dvd drive.
i hope this will resolve the issue.
Jun 25, 2010 | Mercury P4VM800M7 Motherboard
Tv wont turn on
I have a Philips 60" Rear Projection, and all of a sudden I have no picture or sound. I push the power button, and all it does is click. It will keep clicking until I turn it off. Anyone seen this problem?
May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Sound suddenly stopped on the dell lat d810. I
Use the System restore utility (programs -> accessories -> system tools -> system restore) to restore your computer status to a date when your sound was working properly.
Thanks
Apr 12, 2010 | Dell Latitude D810 PC Notebook
While driving, all warning lights on dash suddenly were lit. When I stopped the car, it wouldn't start again and sounded as though the battery was dead.
Probably the alternator died, then used up all the power in your battery to keep the car running.
Have your alternator tested and maybe replaced. The battery needs tested also.
Hope this helps
Sep 13, 2008 | 1995 Volvo 850
ADVENT KC550P Lap Top scren
the pc is standing at command prompt, which means it is unable to find the boot.ini file required to boot into windows
When you say you pressed F8 did you keep pressing it until you got a menu saying Safe Mode,last known good configuration, start in VGA mode etc, if so use last known good configuration and let it reboot.
If still nothing then you will need the windows cd to perform a system repair.
Aug 20, 2008 | Computers & Internet
Lenevo Desk Top computer
your operating system has to be reloaded.
Jun 18, 2008 | Lenovo ThinkPad R51
Computers & Internet Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
