Question about Hitachi 27UX01B 27" TV
Hitachi Standard T.V.
Colour fades to white images along the right side of the screen and the picture arches inward slightly ( on the same side. On the left side of the screen the picture seems to be darker. Middle section is just fine though. Just got this TV second hand and apparently it was working fine prior to that. Could it be something that happened during transportation to our home? Doesn't appear to be too many adjustment buttons on the front to try, and I have no manual. Thank you
    Sergeant:
  • 308 Answers
Some of the problem could be a weak or damaged picture tube - especially if it encountered rough handling in the move. Other possibilities are bad capacitors in the power supply and deflection circuits which are common with this aged set. No adjustments come to mind that could permanently fix these symptoms.
Posted on Feb 11, 2007
Why is my printer printing faded colours
Hi Kath,
I expect you have it sorted by now.
I think you might have had one off the developer tanks stuck or broken. If the developer roller does not turn then the colour quickly fades along the page. If you tried to do a test page and that was good then there was nothing wrong with that side of things.
Good luck.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
Screen distortion
Its due to your screen colour pixels problem! mostly its done due to the presense of magnetic things around the TV. But as far as i know you cannot repair by your own! it needs some expertise*
Dec 08, 2007 | RCA HD56W66 56" HDTV
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Hitachi 50v500, we just put in a new lamp, now the picture on the screen is slightly doubled, what do I do?
Here is what I suggest----look at lettering and or put the mode to 4X3 which is smaller left and right.
Look at the edges of that picture or lettering on screen---this model sometimes has a ghosting where images have a slight shadow, like with rabbit ears.
If this is the case there is a way with the remote to CORRECT IT.
I have the information--confirm if slight ghosting around letters--it can be white or any color.
I have seen this before.
SD TECH
Sep 10, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
PB Minos GP2W screen has coloured lines fades white then black
Most likely it's graphic card problem, but also may be monitor itself. First, check the signal by connecting to TV (if yours has a PC input), then replace card if that shows the same.
Aug 29, 2017 | Computers & Internet
The left side of the screen is blueish?
The blue or yellow haze problem in this projector is because of two factors. 1) Dust buildup inside the optics and 2) Fading colour filters used in the internal optical process.
Inside the projector the white light from the lamp is split into three distinct colours of red, green and blue. Each colour illuminates their own monochrome LCD. Those LCDs are mounted on a prism that combines the separate images and displays the result you see via the lens.
The optical process to split the light up inside the projector is fairly complex and involves many light filters and mirrors to direct the light to the appropriate lcds. Those filters and lenses accumulate dust and also fade over time due to heat and other environmental factors.
I know that sharp sells replacement filters at $100 a piece. I do not know if Hitachi sells replacements.
To remove the dust and change filters you have to take apart the projector in a fairly complex way. I do not suggest that the average user do this. Good luck!
Mar 18, 2009 | Hitachi CP-X445 LCD Projector
Colour fault
A bad solder connection is at fault......needs to be serviced by a qualified tech.......solder any / all bad connetions...........T.
Dec 21, 2007 | Televison & Video
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Weird arch like lines
Hello HollyJ, If possible can you post a picture of the problem, It would help in determining if this is a convergence problem or a pincushion circuit problem. You description while good is a little to general to many possible issues. This sounds like a defection issue but I would not be able to tell unitl I see a picture of the screen, take the picture with a digital camera and the post it to the page using the add image link on the right side of the dialog box. Thank you, Shuttle83,
May 12, 2007 | Philips Magnavox 27MS343S 27" TV
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Hitachi 27UX01B 27" TV Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
