Question about Philips Magnavox 42MF521D/37 Television
Magnavox 42MF230A/37 Plasma TV should i fix it? ?
I need help with trying to fix my tv i really need REAL help its a Philips 42MF230A/37 42 in. HDTV Plasma Television and it turns on and the blue lights up and there is no picture! and then i smell something burning so i turn it off open the back and i see that its burnt this part:
http://cgi.ebay.com/Magnavox-42MF230A-37...
now i want to know if i should replace but the problem is if you look at the item there is no silver heatsink if you look at my part it has them anyways i see that my part one of the silver things burned out i think if i replace it the set should work again....do you think it will?
****THIS IS MY BROKEN PART**** as u can see 1 of the end chip is burned and smells burnt *LOOK AT PICTURE*
http://img519.imageshack.us/my.php?image...
i took it out and if u compare it to the item i want to buy its a lil diffrent cuz the heatsinks are missing(ebay item) DO YOU think its worth replacing or do u think it dead ;(
PLease give me a educated answer i don't want to waste my $$$ PLESE HELP ME
  • maineventinv Apr 05, 2009
    Magnavox 42MF230A/37 plasma blue pwer light comes on no picture just sound what can the problem be? please help
  • 58 Answers
You will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Posted on Dec 05, 2008
Try to fix stanby mode
What is the problem you faces with this TV? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 22, 2015 | Philips 42MF230A/37 42 in. Plasma HDTV
42" magnavox plasma tv lost
The power supply feed deferent voltages to the TV and the Problem is the electrolytic caps need change out on the power supply module, or you can go to www.partstor.com and get a new one.
Aug 30, 2011 | Televison & Video
My 42mf230a/37 plasma tv has sound but no picture
Check the power supply, Y and Z sustain boards caps, fuses, burnt parts first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 23, 2010 | Philips 42MF230A/37 42 in. Plasma HDTV
Philips tv wont turn on and makes a clicking noise when plugged into an outlet
It is that sound that gives it away, this is a typical switchmode Power Supply problem. Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Philips 42MF230A/37 42 in. Plasma HDTV
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Jan 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a 42mf230a/37 magnavox. no pic no sound. the red standbye light comes on but the tv has to be unplugged to turn off. the light used to turn green but now doesnt do that, it just clicks once when...
normaly the Plama as LCD TV , and the new LED Tech.dont have replace boards yet available on the market. This is a defective control board. All TV companys, dont have spares to sell, they say "Buy a newone".This TVs has 5 to 10 years timelife.
Nov 22, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Horizontal lines on screen
well if they run all the way up and are on every input through then menu the panel is NG, some panels are around $500 now.
Jul 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
This sounds like your Z sustain board has gone bad. I just repaired an HP plasma today with the same complaint. All the modules inside were LG. The Z board is the one on the Right side of the set with the cover off or facing the back. You might have 1 or 2 ceramic fuses on it, check them, if one is bad Replace the board.
Apr 28, 2009 | Philips 42MF230A/37 42 in. Plasma HDTV
Philips Magnavox 42MF521D/37 Television Logo
1,271 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
