I have just changed propane providers and now my flame is red or orange intermittently depending on outside temperature, I have had the propane company come out and recheck, they readusted the regulator pressures, but that did not change the result, please help, I did not have this problem before changing tanks?
  • 1,420 Answers
Did they indicate on a paper what they are getting for pressure under full-load? You should be getting between 9.5 and 10.5 inches of water column when all appliances are running. An orange flame indicates low gas pressure, not enough air mixture, or dirty burners. The intermittent condition when cooler outside makes me think that you have a bad propane regulator or too high of moisture in your propane tank. Did you change companies for price or quality of service? You may have made a bad choice.
Posted on Dec 05, 2008
Replaced gas valve on oven. can't seem to adjust flame. Baffle wide open. large yellow flames. How can I tell if this valve is for Nat. gas. I have prop.
Too much gas or to little air or both with orange flame.
Check to make sure all pipes and airways after regulator are clear.
If you are sure air mix is max than you need to check how much pressure is going in and coming out of gas valve there is typically a port on valve to do so. You need a manometer to do this. In a pinch you can make one check internet..
For propane you should be getting 9 to 11 inches water column depending on BTU of oven.
Typically natural gas controller/regulator is less 4 inches wc in which flame would be very small if it was set up for propane and you installed natural gas regulator.
Jan 14, 2015 | Eaton Nc-1425-5a Gas Valve
How can i convert a sta-rite max E therm 400 HD from natural gas to propane
On the valve that controls the flame is a brass part that mixes the gas with air to make the flame. That part must be replaced with the part in the kit. The hole size is different so you can't skip this. Once it has been changed, then you may have to adhust the metal sleve that lets air in so the flame has a blue flame at the tips...no orange tips in the flame.
Jun 06, 2014 | Heating & Cooling
Why does my burners not ignite into a blue flame
The color of the flame can be affected by a few different things. here are three of them: 1. If there is a food substance contacting the burner where the flame comes out, this will give the flame an orange tint. 2. If the propane is being burned at a very high rate, the flame can become invisible in daylight-like conditions. 3. If the propane is being burned at a very low rate it can also have an orange tint. Hope this is clarifying.
May 24, 2014 | American Range AF45LP Deep Fryer
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Could be that the burner needs cleaning dirt in the burner tubes
Nov 02, 2012 | Blue Flame Heating & Cooling
I have a 40,000 BTU propane reddy heater. I just refilled the tank and attached it to the heater like I normally do but now when I start it it will run fine then it will flare up and shoot out orange flame...
Did they over fill the tank and you are getting pure liquid to the heater..... Sounds like when you use a propane bottle hand torch and tip it up side down the flame turns orange and goes out. Also the regulator vent may have gotten plugged with dirt or ice. May try and bleed some of the propane pressure off of the top of the tank....... But make sure you have it outside and plenty of ventaltion and no open flame any where...... Propane is lighter than air so it settles down on the ground at the lowest point.....hope this helps..... Or you could take it back to your suppler and get a different tank.
Feb 01, 2011 | Reddy Heater RLP100 Portable Forced Air...
Propane flame is not blue but too high
A yellow or orange flame means (1) too much fuel, or (2) not enough air. Make sure the air ports where the regulator attaches are clear and that spiders or bugs haven't built a nest in the burner tube. If that's all clear, it's likely that the propane regulator has failed and is allowing too much fuel to enter the burner tube. The regulators are inexpensive and are not repairable; get a replacement unit.
Oct 08, 2009 | Weber Gas Go-Anywhere Grill
Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Feb 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy heater model 28725
propane heater uses a hot surface ignitor. this operates off 120 volts and glows red/orange when actuated. it stays lit throughout the heater on operation.  on the backplate of the combustion chamber is a high limit with two wires coming off it.  these two wires connect to the spade connectors on the flame detector cappillary.  Once you establish a fire, the flame detector generates a 750 millivolt signal which is applied to the pilot/main valve assembly.  My diagram will show this. 1fa8284.jpg
Oct 12, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
