Question about Canon imageCLASS MF5550 All-In-One Laser Printer
Paper feed Suddenly, printed paper started feeding out back of printer rather than front. This is a Cannon MF5550 all in one.
    President:
  • Canon Master
  • 990 Answers
There should have a wheel (knob)right on the paper exit area, just close it , paper will be come out to front
Posted on Dec 08, 2008
Paper Feed problems for Cannon MP600
Mechanism Problem replace the mechanism with new one.
Jan 01, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Please tell me how to enable duplex printing in my Cannon MP470. This option is checked on the printing dialog box, but only one side of paper is being printed. Thanks in advance for your help! SMK
The printing dialogue box may allow you to select duplex printing but you may have to physically turn the paper over yourself UNLESS you purchased a DUPLEXER for your printer.
If the paper feeds from the back and the finished product comes out the front, you will have feed the paper back into the back of the printer.
Apr 03, 2011 | Canon PIXMA MP470 All-in-One Printer
My paper seems to not want to feed properly it suddenly shifts to the side....Cannon ip3500
Make sure that the paper guide is up against the right hand side of the paper in the feed tray. You should not be adle to move the paper sideys in the feed tray. If you can, the guide is not set right.
Feb 11, 2011 | Office Equipment & Supplies
My printer is feeding more than one page at a time my printer is cannon 3000
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results?
May 23, 2009 | Office Equipment & Supplies
Cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Canon PIXMA iP1600 Printer
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
Printer fails to feed paper for printing
try gently rubbing the take up roller with a damp cloth - let dry and try with no more than fifteen or twenty sheets of paper in the feed tray
Oct 29, 2008 | Kodak Easyshare Printer G600 Thermo...
Alarm will not clear "Supply Rec. Paper Tray: LTR, their are no jams and the cartridge is installed properly. MF5550
Check paper size
If it is ok go to print job cancel and cancel all jobs
if the error comes while computer connected printing
before click ok go to peinter properties and change input paper size to A4 and out put as match paper size then click ok .
Mar 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Cannon imageclass mf5550 troubleshooting
The document feeder on this machine uses a separation and a feed roller ,the pad is on the bottom and the roller sits on top . in most cases the pad will be white if it is not it must be cleaned .use isopropyl alcohol. then clean the roller using water on a paper towel. On the tray issue if the paper is torn or nicked the sensor flag may be damaged if it is you will need a service call . if the paper is not nicked check to see if the default paper size has been programmed into the user settings on the copier [ read the owners man.] When you send a print to the printer go to printing preferences and check on the paper size being sent to the printer it must match the paper size loaded into the machine
Jan 02, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS MF5550 All-In-One Laser Printer Logo
130 people viewed this question
old marine
old marine
