Question about Canon imageCLASS MF5550 All-In-One Laser Printer
Printed sheets are coming out back of printer rather than front. What should I do
  • treschic Dec 07, 2008
    Thank you for your response and I believe you have described the solution to my problem. However, I cannot find the "face up cover" to close it.
  • 2,012 Answers
You have the "face up cover" open. You should be able to just pivot this cover up on its hinges and close it. Then the paper will come out the front (face down).
Posted on Dec 05, 2008
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
Sometimes the printed sheets exit from the back of the printer, rather than the front (yes the paper & tray are correctly loaded into the printer)
Is you back cover CLOSED ??? there is no way that the paper exits from the back of this printer if it is closed..check it :)
May 23, 2010 | Samsung SCX-4300 Monochrome Laser...
Printed out a inkjet magnet sheet now won't anything else! Help!
OK Christina, did the whole magnet page come out without any missing tear outs or pieces? You probably have a stuck piece of sticky paper in your feed or rollers. Look in your manual for clearing paper jams and examine your rollers while your at it from stray pieces of paper.
Jun 27, 2009 | Office Equipment & Supplies
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark X7170 not ejecting printed sheets
Time to get a new printer, because you cannot get the parts.
Mar 01, 2007 | Lexmark X7170 All-In-One InkJet Printer
Canon imageCLASS MF5550 All-In-One Laser Printer Logo
20 people viewed this question
old marine
old marine
