Question about Neuros (4010100) (128 MB) MP3 Player
Mp3 player My mp3 player will not charge. I have been charging it for 2 days and when i unplug it from the charger it won't play. It still says the battery is dead. The mp3 player is 2 months old.
  • 102 Answers
Well, charging the battery alot may cause it to malfunction. So you have to charge your battery only when in is near zero (empty), and for no more than 8 hours depending on what device you use. Now your battery is dead, so you got to replace it. Goodluck
Posted on May 25, 2007
SOURCE:
Gigaware mp3 will not hold its charge, when i unplug usb cord it dies out
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 28, 2012 | Audio Players & Recorders
My zune 4g red will turn on and work when plugged into the charger, but as soon as I unplug it from the charger it goes off and I cannot do anything with it. I haven't tried to restore it, not sure...
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 29, 2011 | Audio Players & Recorders
My Samung P3 will no longer keep a charge. I can leave it on the charger all day, then turn it on and the display shows a half charge. After which, it will just shut off saying battery not charged. What...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 08, 2011 | Samsung YP-P3JCB Digital Media Player
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
Battery fully charged,but will not turn on when unplugged from charging cable. only plays when plugged into charger??
The battery wire inside may have broken off...its a common problem in sansa clip...if you are comfortable opening it up,you need to solder the wire into place correctly...
Sep 26, 2009 | SanDisk Sansa Clip MP3 Player
Battery dead unless pluged into computer. Charges
Friend, the power switch is damage thats why the charger acted as switch. replace the power switch
Jul 17, 2009 | Sony NWZ-E436F MP3 Player
Mp3 player won't cut on
when you plug a charger to your mp3 it plays, because you power from a charger, part of current goes to aset and make it play and also charge your battery.
when you unplug it from charger than battery does not manage to provide power to set.
get a meter and set at amps dc. and check your battery current out side.
i suspect that your battery is not holding charge.
Mar 28, 2009 | Samsung YP-K3 MP3 Player
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
No power
It is very likely your battery is used up, if it still plays music while on the charger. If it can play on the charger you need a new battery.
Jul 15, 2007 | Samsung YH-925 MP3 Player
Player won't hold charge
Yes your battery capacity is below standard you'll need to take the battery out and measure its capacity and if its below 3v then you will need to rejuvenate it.
Jul 24, 2006 | Philips GoGear HDD060 MP3 Player
Neuros (4010100) (128 MB) MP3 Player Logo
100 people viewed this question
Top Neuros Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Neuros Audio Player and Recorder Expert? Answer questions, earn points and help others
