Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
BOSCH washer, the door won't unlock and is reading E:04
The LED reading on my front loader BOSCH wasing maching is not opening can yu help..thank you
I used a thin screw to release the lock through the access hole and this released it after rotating the round panel a bit. The manual release on my Bosch is a nylon deal that hangs down from the top. Just pull down lightly and open door. You may have to reach up past the drain to get a hold of the nylon string. The access opening is fairly sharp.
Posted on Jan 13, 2012
2 Suggested Answers
  • 5 Answers
SOURCE: bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Posted on Mar 02, 2009
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
Door wont open after cycle has finished, have put on a different cycle didnt work either, pluged out maching for 30 min didnt work either, can you help
Hi.
The door does not open because there is water detected inside the machine. Water must be removed through the drain filter connected to drain pump.
Disconnect power.
If front loader remove the trim panel at the base of the machine. Top loader have access at the bottom or at the back.
Locate the drain filter access at one side.
Remove drain filter cap.
Collect water using containers (have them ready, a lot of water will flow out).
Put back cap and trim and reapply power.
Emptying water from drain lines is usually enough to unlock the door. If that does not work, then the door is opened reaching back side of the door latch (from inside the washer's cabinet). Access is from top, after removing panel, or from bottom. Some front loader has an emergency unlock cord inside that can be reached undoing completely the drain filter. The procedure requires disassembling and should be done by a technician.
You can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Washing Machines
Bosch Washing Maching Model: WFMC5301UC Door won't unlock. No water going through the cycle
It might be defective door lock or defective control board or defective control panel and more over could be defective pump
Aug 16, 2011 | Bosch Washing Machines
CANNOT GET DOOR TO OPEN BOSCH FRONT LOADER MODEL NUMBER WFVC5400UC. I TRIED TO UNPLUG FOR 5 MINUTES BUT NO SUCCESS.
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck.
**The door typically won't unlock as a result of the unit failing to drain due to an obstruction, excessive suds, also the E13 error (though it won't always show up) kind of one in the same...usually, but the pump failing can cause this as well**
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
This is the info regarding the WTVC ( vision ) series Bosch washers which differ from other prior models.
**Unplug the washer from it's power source...safety first**
The next step is as follows,
Following this ( or in reverse order it's your call if you think there may be substantial water still present ) I'd do this step first...checking the pump filter. It may be a good plan to have towels close by, or a wet-dry shop vacuum.
It's as follows...
Then the filter removal...
That should resolve the problem, As I also alluded to before there is a small possibility the pump itself is faulty, but not likely.
Thanks for choosing FixYa and good luck. Let me know if you need further assistance or if any of this is unclear.
Regards,
Macmarkus :)
Apr 25, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Hello - we have a Bosch Nexxt 100 Series Washer. The front loader door is locked and I cannot get it to unlock. We have a load of clothes in the washer. I have tried to run the "spin" cycle...
Easy to do....But may need a service call from a pro to fix the underlying issue.
Take the bottom right little door off and try not to cut yourself reaching in..(OH TURN OF THE POWER). reaching in after looking with a flashlight try to grap the zip tie looking plastic hanging there and pull it down gently and it will unlock.
Of course make sure you tried to unplug it first for 10 minutes and then try turning it on again in spin mode.
Thanks,
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Mold on gray rubber seal in Bosch washing machine
I use to sell bosch front loading washers for about 3 years, its a common problem on all front loading washers. Try a hot wash through the machine, if no joy then remove the seal and wash in hot soapy water. Make sure you replace the seal while its still hot from wasing if you take it off.
If still no joy, the call a service person and replace the seal. Its just one of those things.
Jun 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Maytag washer MAH 5500b FL code and door will not unlock.
Open the detergent dispenser door on top of mach. There you will find a small yellow nylon cord, pull on the cord and the door should open
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
558 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
