DSM 730 Changing the sender name
We would like to change the name of the company sent on the faxes to other machines...how do we do it?!
4 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: panafax uf585
here is the manual
http://service.us.panasonic.com/OPERMANPDF/UF585.PDF
Posted on Feb 15, 2008
POCBM
  • 121 Answers
SOURCE: Sharp Fax - Change outgoing name/number - HELP!
Try this:
http://www.sharpusa.com/files/fax_man_FO_DC500_600.pdf
Hope it helps
Posted on Mar 14, 2009
Logjam
  • 159 Answers
SOURCE: Change company name on fax header on a Canon
Press Function then Data registration.SET. use the up and down arrow keys to scroll through the settings. When you get to where you want, press SET again. When you have finished press STOP/RESET. In this case you need to re enter the TX Terminal ID.
Posted on Oct 06, 2010
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
I have Gestetner DSM 730 and it give me an error of serial no: k8654300136, so the problem
how can I reset one copy Gestetner DSM 730 if screnn touch does not afiche we do not even know the code up above.
Feb 11, 2012 | Gestetner DSm730 Black and White Copier
We have a FAX-2820. this is a dumb question, but does the fax header line come from the sender when we are receiving the fax? Does a header go out on any fax we would send out?
Yes, The fax header should show you who sent the fax to you. Every fax is supposed to have a terminal ID (senders fax number and Name)
Andrew
Sep 22, 2011 | Brother IntelliFax-2820 Laser Fax
How do you stop incomming repeat faxes
The sender has to be told to stop THEIR fax machine. Your fax machine is OK
Jan 22, 2009 | Office Equipment & Supplies
Want to change the heading to reflect my name.
On Page 6-6 of the Operation Manual, the Settings to adjust the Sender's Name (which you can store up to 99 Names) is done through the TTI SELECTOR. On my machine, the TTI SELECTOR Button is located just under the LCD Screen - last button on the right. There is little else mentioned of this therefore I assume the procedure is quite simple. However the Manual states "To Select a Sender's Name" I was hoping it went on to say, to also EDIT and/or INCLUDE a Sender's Name. I would start with the TTI SELECTOR and hope that solves your problem. Good Luck
Jan 12, 2009 | Canon Laser Class 8500 Printer
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
Changing user name on used machine
there is the HELP key on the pannel board press it and go in the user data so you can find your desire setting or go by function key
Sep 20, 2007 | HP 1240 Plain Paper Inkjet Fax
Stretched text on faxes
In my experience, this type of problem is on the sender's end and not the receivers. We have sent faxes before and while they are sending, the paper on our end misfeeds and the received copy on the other end is stretched and unreadable. One way to determine this is to have a few different people from different locations send you faxes. If all the faxes have this problem, then it is a good bet it is a problem on your end. If not, then it is probably a problem with this particular sender's fax machine. I hope this helps.
Jul 27, 2007 | HP 1040 Plain Paper Inkjet Fax
Sender Id
Sender ID ecblank.gif ecblank.gif dot.gif ecblank.gif This is a descriptive title that identifies the sender -- usually the location of your fax machine or the name of your company or office. It is printed at the top of every fax you send. You can enter up to 32 characters. The first 16 characters will also be used as your Personal ID, which may appear on the displays or reports of other fax machines you are communicating with
Setting the TSI/CSI and Sender ID ecblank.gif ecblank.gif dot.gif ecblank.gif1 Press Menu/Exit to enter the menu.
2 Input speed access number 02. 3 Input up to 20 numbers and characters (0-9/Hyphen/ Space/+), press Enter. 4 Press Menu/Exit.
Sep 27, 2006 | OKIFAX 5950 Plain Paper LED Fax
29 people viewed this question
k24674
jasbo
jasbo
