Question about Jenn-Air JED8430 Electric Cooktop
Removing a burned milk/sugar solution from a Jenn-Air cooktop.
A milk sugar combination boiled over and spilled on the cooktop. Is there any cleaner that can be used to remove it.
  • Anonymous Mar 27, 2014
    I burned a wooden cutting board on my ceramic cooktop. Now there is a residue like varnish that won't come off. Used Weider cleaner to no avail.
    Sergeant:
    Champion:
  • 324 Answers
Try a razor blade.i use them alot when i am doing service.
Posted on Dec 06, 2008
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 15, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I was making hot coco on my glass cooktop and some of it boiled over onto the stove. I tried to get it off with the cleaner but only some came off what else can i do? Plase help me is new!
get some oven cleaner spray......
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 14, 2010 | Jenn-Air Cooktops
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    WHAT DO I USE TO CLEAN AN ELECTRIC JENN-AIR CERAMIC COOKTOP; THE BURNT FOOD BUILDUP.
    a good product is CERAMABRYTE. it is designed for ceramic cooktops and is a white lotion type cleaner. if there is a lot of burned buildup you may also need to purchase a special scraper with a blade in it. but make sure you smear the cleanser on FIRST or you will scratch the surface.
    Oct 24, 2009 | Jenn-Air JED8230 Electric Cooktop
    All 4 igniters keep clicking, when one is on
    All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
    Aug 05, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
    Water boiled over into control knobs for the cook top elements.
    Just fixed this problem and repaired the corner of the Ceran cooktop.
    Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
    The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
    "Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
    In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
    My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
    You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
    When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
    I hope this helps.
    Apr 02, 2009 | Jenn-Air JED8430 Electric Cooktop
    Can't remove burnt milk from right burner on stovetop?
    I'm happy to say burnt milk can be removed with a combination of cerama bryte and let sit for one hour and then lots o elbow grease hard rubbling with also applying Mr. Clean Magic Eraser. The Mr. Clean Magic Eraser works very well but you have to still rub alot to get it safely scratch-free removed.
    Dec 13, 2008 | Jenn-Air JED8430 Electric Cooktop
    Boiling liquid ran down into ignition switch, now light stays on
    is this the front right burner? i looked at one yesterday where milked spilled into it.it burnt out the little board under the know. i am not sure of the model # on the one i worked on.
    Oct 12, 2008 | Jenn-Air JED8430 Electric Cooktop
    Maytag gemini schott ceran stove top
    Sugar spills on a hot surface will 'pit' the glass surface. There is no way to repair. The damage caused to the surface is only cosmetic and will not affect the performance or operation.
    Jun 16, 2008 | Cooktops
    Jenn-Air JGD8130
    The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
    Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
    Jenn-Air JED8430 Electric Cooktop Logo
    200 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    jason
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
