Question about Home
Can't remove front cover on a triton aqua sensation shower.
It's a pretty old shower, hot & cold fed. undone the three screws that anchor the front to the back. can't figure out how to remove dial
  • peterfowell Dec 06, 2008
    wet hands and stressing for ya. nice one.
  • machinedred Mar 14, 2009
    cant remove the shiny hot cold corner pieces
    Problem Solver:
  • 5 Answers
Just try a little gentle leveredge,it shud com off
Posted on Dec 05, 2008
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
No water, hot or cold from Triton T90si. Any ideas please?
The Triton t90si is fed from the tank in your attic.This also feeds the cold water in your bathroom.If you still have cold water in the bathroom tap,it means that there is water in the attic tank so the problem is somewhere else.I believe there is a bleed valve on these showers so maybe that is the problem. It may also be that the pipes are clogged up with dirt or limescale.The water filter may need cleaning. Hope this will help with your thinking on the problem.
Dec 19, 2010 | Home
How to remove the cover plate from a triton t80 shower
Remove handle by locating set screw. Escutcheon (cover plate ) screws are now accessible to be removed.
Oct 06, 2010 | American Standard Showerhead & Valve Trim ...
How do I open a Triton shower box ?
there are usually screws on the top and the bottom of the shower unit holding the front cover on.
Apr 11, 2010 | Home
How do i remove the frontcover on a triton t-40 shower pump
I'm not familiar with this model but on other models there are usually screws on the top and the bottom of the shower unit holding the front cover on. Failing this you could try gently pulling off the control knobs, sometimes fixing screws can be hidden underneath.
Apr 10, 2010 | Plumbing
Triton t80i water only warm in winter
That sounds like a water heater problem, wheres the heater at in your home. If it is effected by the outside weather i.e. the heater is in a cold environment then it would effect the hot water output. try turning up the thermostat on the heater if it is gas then it should be knob on the outside if it is electric you will need to remove the top or the bottom cover and adjust it with a screw driver. If this does not work the let me know and we try some other things. With the weather/temp outside effecting the water temp in the shower then I have a hard time believing it is the shower its self.
Jan 24, 2009 | Home
Home Logo
465 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
