Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
Aspire 3002 Nlc note book DVD Comboo is not recognised
Hi, I have a Acer Aspire 3002 Nlc Laptop which has DVD Combo drive It is the one which was given along with the laptop. The problem is I have installed the drivers but the properties shows me ? drivers How can i rectify the problem Hope any one of you can give me solution Kind Regards Suresh Mattaparthi
    Sergeant:
  • 310 Answers
Hi, sorry you might need to explain a little better, but i will try. The DVD Combo drive doesnt need any drivers to work, the only thing you need is somthing like powerdvd to watch films, if the drive is not reading cds or dvds and in device manager you have a yellow tag, probably next to Primary ide its windows drivers, but if you could explain in a little more detail will be happy to help.. All the best John
Posted on Mar 02, 2007
My acer aspire cd/dvd rom wont recognise blank dvd
You might need to replace the optical sensor...
Hope that helps! Please rate my solution
Nov 14, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
SLIMTYPE_DVDRW_SOSW-833S Drivers
go to device manager, select CD/DVD rom and right click then select properties. check the DVD Region Tab and see what is selected. make sure it is set to your country. hope this helps
Nov 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have an Acer Aspire 5670 Note book Computer
There is a small hole on the face of the tray which is used to open the tray in this kind of situation. Use some needle and push into the hole. If the tray does not come out, you have to open the laptop and remove the tray.
Sep 20, 2009 | Computers & Internet
Acer Aspire 5920G wont play dvd, it wont even recognise them!
If it recognises cd but not dvd it means the drive is faulty. There is 2 lasers one for cd and one for dvd. The dvd laser is faulty. It also means that it is not dirty lens because it reads cd's.
Aug 18, 2009 | Acer Aspire 5920 AS5920 Notebook
MAY U PLZ ASSIST ME WITH MY ACER LAPTOP ASPIRE 4330 THE DRIVE IS UNABLE TO WRITE ALL THE DVDS BUT IT IS ABLE TO READ DVDS THE ONLY PROBLEM IS BURNING DVDS. HOW CAN I ENHENCE MY DVD/CD-RW COMBO TO WRITE THE...
No Sir, Acer Aspire 4330 comes with different Optical Media Loadings, ( You can see a pdf file here )
Like;
  • DVD/CD-RW combo drive
  • 8X DVD-Super Multi double-layer drive.
But you have the first one, The Combo drive not the super so you can READ both CD's DVD's but can write only CD's.
Hope this removes your dilemma.
If helpful, kindly do Rate!
Jul 18, 2009 | Acer Aspire 5720-6661 Notebook PC
DVD/CD combo drive will read but bot write
Your combo drive has gone bad, get it repaired
Jul 16, 2009 | Lite On (SOHR-5239V) CD-RW Burner
External widescreen monitor for laptop
You have to make sure that the laptop could provide the required resolution of the monitor, because of the laptop could only give1280 x 1024 and the monitor is requiring 1600 x 1024, then expect that you will get that result.
Try changing the resolution of the laptop. Set it to 1024 x 768.
Have a good day!
May 18, 2009 | Acer Aspire 3002LCi Notebook
No driver (?) for aspire 3002
try to search in the acer website: www.acerpanam.com
Jun 13, 2008 | Acer Aspire 3000 Notebook
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
153 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
