Question about Canon PIXMA MX310 All-In-One Printer
U163 keeps coming up!!
Replaced cartridge but still can not use, just keeps coming up with U163! can not find what this means in the Manual, can anyone help?
  • 1 more comment
  • Anonymous Mar 27, 2009
    I have the same problem. I just refilled the cartridges, installed and I keep getting the error.
  • Anonymous Apr 07, 2009
    I have done all of this and replaced the new cartridge correctly. I can not get the error message to go away.
  • Anonymous May 13, 2009
    Same problem .... have tried the solution and still coming up U163. Have even turned off machine and still there!!
    Scholar:
  • 134 Answers
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. Confirm that the printer is powered on
  2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
Note: After confirming that the scanning unit support is fixed into position, release your hands.
3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
Note: - Do not attempt to reattach the protective tape once you have removed it.
- Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot**One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
8. Confirm that the ink cartridges are installed properly.
<1> The ink cartridge is not installed properly.
<2> The ink cartridge is installed properly.
  1. Fold the scanning unit support and close the scanning unit (printer cover).
  2. Wait until the preparatory operation is complete; it takes about one to two minutes.
I hoe it helps!!!
Posted on Dec 09, 2008
What does mean check ink u163
Ink of your printer's cartridge may have finished. You need to replace it to continue your work.
Jul 22, 2014 | Canon Office Equipment & Supplies
Recognize ink cartridges
Are the cartridges the same as recommended by OEM? If not, the printer will not recognize it.
Switch off, check if printer still your default. Do a test. If no luck, go to tools and clean and align cartridges. GL
Aug 18, 2013 | Canon Pixma MX360 Printer
I have canon pixma 310 its say chech ink u163 what thats mean
Good Day Sandip920!
Error U163 means, the printer detected that your black ink cartridge has been refilled with new ink.
It is very easy to clear this error and keep your printer printing.
How?
1. Turn on your printer.
2. When error U163 appears, press and hold the STOP/RESET buton on the printer. Hold it down until the printer self restart and initialize.
3. if after U163 is cleared off and appear another error, U162, press and hold again the STOP/RESET button and wait till printer self restart and initialize again.
Hope this helps!
Don't forget to rate my answer.
Thanks for asking Fixya.
Sep 16, 2011 | Canon PIXMA MX310 All-In-One Printer
Error U163
I can then help you with your specific problem.
Error Code U163 (Ink Cartridge Empty or Low)
First of all, Yes, this is a common problem.
When you open your printer up, by lifting the Scan Cover, you will see lights blinking for the cartridge that is low or is empty.
1.) A lamp blinking once every three seconds means your cartridge is low.
2.) A lamp blinking once every second means your cartridge is empty.
Using your printer with an empty ink cartridge is capable of harming your printer, according to Canon Engineers.
Until such time as you can replace the cartridge you can use the method described below to temporarily turn off the error message.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Feb 28, 2011 | Canon PIXMA MX310 All-In-One Printer
Error code U163 on cannon pixma mp220 printer
Those cartridges don't refill unless you have a way to reset the internal chip. Check online for refillable cartridges or a chip resetter. For priming you go into printer properties and choose maintenance and head cleaning, or choose cleaning from the front panel.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
The problem appears is u163( black ink) although
Canon MX300
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Canon PIXMA MX310 All-In-One Printer
I am getting a U163 check ink error, I just installed a new b&W cartridge but color cartridge is empty but still in printer.
Replace the ink
cartridge(s), or press the
OK button.
When selecting to press
the OK button, ink may
run out during printing.
Oct 11, 2009 | Canon MX300 Office All-In-One Printer
U163 problem
More the likley, your printer's manufacturer does not allow for the use of refilled ink cartridges on their products.
Please purchase a factory new cartridge from the manufactuer of the printer.
Aug 14, 2009 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
472 people viewed this question
old marine
old marine
