Question about Sony Playstation 3 (PS3) Console
PS3 dualshock controller works erratically on certain games
It started when my PS3 suddenly stopped recognizing (only) game disks. Blueray movies played ok, as did normal DVDs. I found a "Corrupted data" file on my games/data section. No real idea how it happened; but I deleted it and did a quick restore. Reloaded all my dowloads, etc. Things work...games boot. But now the Dualshock controller acts...weird. After quitting a game, it would sometimes fail to function, although a quick controller shutoff/restart (the PS button always works) would reset it. In Civ Revolutions, the city maintence screen (L1 from the world map) looks completely different: the menu boxes appear out of place and shake slightly, and none of the controls work - the only way out is to quit the game using the PS button. This also ALWAYS makes the controller an inert paperweight until I reset it. Tiger Woods '09 is playable until I try to use the gameface editor to change my character's appearance...there the interface again fails, although I can O out without quitting. Ironically, some games work fine. Call of Duty 4 works completely, as does (As far as I can tell; I haven't tried everything on it yet) Oblivion:Gme of the year edition. And sometimes while on the playstation start screen, it will stop allowing left-right movement on the menus...although up down movement is unnafected. The controller seems to work OK on other PS3 systems, so it doesn't appear to be the controller, which is only 2 months old... and the PS3 is only 6 months.
Some friends say its a scripting problem and suggest a total reformat but as this would take several tedious hours and a lot of downloading (again), I was hoping there might be a less drastic solution.
Thanks in advance;
Mike
  • 4102 Answers
SOURCE: No Disks will Load!
Hi it sounds like the ps3 has over heated and this isnt cheap to get repaired neither will cost nearly as much as it did to buy.
If you have had the ps3 sitting on carpet or on top of something like cable box or video or dvd player this will cause the unit to overheat.
Check to see if you can hear the fan working if not you might be luvky and replacing the fan can solve this problem.
If the fan is working then it will need to be taken to repair shop as it is impossible to get the spares for these as the shops can charge a fortune to repaur them.
Also was i brought new or second hand if new take it back they will replace it for you but wont give refund.
The problem with all ps3 is that the fan is only just strong enough to keep it cool alot of people have this same problem even using it on carpet will cause it to overheat it needs to be on flat surface not ontop of anything electrical.
If you need the board replacing this will cost nearlly as much as replacing the whole unit im sorry their isnt much you can do but i see alot of ps3 with this problem everyday must be a fault in production if it still under warranty send it back.
Let me know how you get on ok
Posted on Jan 03, 2008
SOURCE: Photo game face for Tiger Woods 08 on PS3
where do i upload on that site
Posted on Feb 16, 2008
PIMPKING100
  • 6 Answers
SOURCE: Error on Game screen
U UNPLUGGED THE SECON CONTROLLER SO PLUG IT BACK IN DUH
Posted on Jul 01, 2008
Cerfer39
  • 709 Answers
SOURCE: For PS2 "The Dualshock 2
This could be the PS2 console. You need to try a different Dual Shock controller to determine if the problem is the controller itself or the ports on the Playstation. The normal problem here is a dirty connector on the Playstation. Clean the connector or you may need to check the Fuses inside the Playstation. This requires specialized skillls.
I have seen where Dogs have chewed the cable running from a controller, and caused the problem.
Posted on Dec 30, 2008
Seritath
  • 86 Answers
SOURCE: the dualshock 2 analog controller is not detected
Well its probable your controlor port either needs to be cleaned out or your controlers wire is lose.I might be easier to just buy a new controler and if the problem persists clean out the port.
Posted on May 07, 2009
Ps3 player wont play blueray discs says needs up date
I don't believe there is an update that will make the Blueray stop reading, or start working. Your disk drive might be bad and needs to be replaced.
Sep 26, 2014 | Sony Playstation 3 (PS3) Console
My ps3 stop playing all blueray disk (games and movies) but it play games and movies that are not blueray . when i put in a bd a message come up that say an error has happen doing start up and then givings...
Hi, You have the model PS3 with the dual laser, Ones for Blue Ray and ones for standard definition. They are part of the same assembly and cant be changed individually, You will need to replace the whole laser deck if you are good with openeing thins up but if not then search ebay for a complete blue ray drive and its a simple plug out plug in swap over. There are loads of guides on youtube for laser replacement. Be sure to use the Serial coee on the console label to get the correct compatible laser. If you are in Ireland or UK we can do the repair for you. Just reply to this comment if interested.
May 11, 2011 | Video Game Consoles & Games
My PS3 will play PS3 games sometimes. It quit
sounds like a dead Laser they are a dual laser will read DVDs n CDs but wont read Blueray movies or PS3 games Laser might need replacing
Oct 19, 2009 | Sony Playstation 3 (PS3) Console
My 60gb ps3 wont play games but it plays blueray movies and dvds
hahahahahha upgrade to xbox 360 you ******* *********
Sep 20, 2009 | Video Game Consoles & Games
My ps3 games will not play at all will play bluerays but will not recognise any game at all
Laser is bad in the drive which is why it will recognize bluerays but not games. Laser requires different strengths to read certain discs and if the laser is weak in any way then it won't be able to read certain discs. You can get new lasers on Ebay or even replace the whole drive which you can get on Ebay as well.
Aug 28, 2009 | Nintendo Game Boy Advance Console
PS3 Dualshock Does not Charge.
hi i had this problem my controller would not charge although my head set would useing the same usb cable .i brought a new controller and tried two usb leads it was no different .this is the silly bit go and buy a new genuine ps3 usb cable and and i promise you all your problems will be solved .i have no idea y the cables stop working with only the conroller but they do i hope this helps all you people pulling your hair out trust me this will work
May 10, 2009 | Sony Dual Shock 3 Controller for...
Ps3 reads ps2 games and movies, but not ps1 or ps3 games
your blueray lens
the ps3 has 2 different lenses in the disk drive 1 is blueray and the other is just a basic dvd cd lens<
your blueray lens will have burned out if your still under warranty you should be fine to call sony and request a free repair if your not under warranty it will cost around £120
hope this helps
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 won't play games, dvd's or blueray movies
sounds like the optical reader is broken... u have any warranty left?
Aug 26, 2008 | Activision Call of Duty 4 Modern Warfare...
Ps3 won't play my ps3 disks or movies
Usually that means that the BlueRay drive is bad. You can replace the laser module to take care of it. THey are available on eb@y for $70 or so. Or you could return it to teh store, or send it out to Sony.
Jul 22, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
207 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
