Question about Pyramid PS14KX 270-Watt Power Supply
Pyramid PS-14KX IMMEDIATELY blows fuse when turned on - (new mode
Hi
When I turn on the ps-14kx... the on switch does not light up red...but the normal light does for a few seconds then totally off and the fuse is burn out. I opened the box and looked at the mother board and I can't see any burn marks or broken legs of transistors. New to these types of machines. Any assistance would be greatly appreciated. THANKS a bunch!!
Jules
2 Suggested Answers
micromend
  • 748 Answers
SOURCE: Pyramid Power Supply manual
I found one at www.retrevo.com
Posted on Mar 25, 2009
I have a Pyramid PS-52kx. I need to know the value of R13 on the controller board, and cross-reference for TYN416
I HAVE A PYRAMID PS-52KX I NEED TO KNOW THE R13 RESISTOR OHMS AN TOLARENCE AND WATT.
Mar 07, 2011 | Pyramid PS52K Amplifier
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
Connecting a Cobra 29LTD to a Pyramid PS-3KX 13.8VDC Power Supply
The wires should just attach to the red and black terminals on the radio, strip some wire unscrew the terminals a little wrap behind, and tighten again. Good luck! Or buy some banana plugs and they will plug right in the front
Dec 18, 2008 | Cobra 29 LTD CB Radio
Pyramid ps-36kx
Generally, the fuse only blows when the rectifiers fail. In other Pyramid supplies, they use a square, 4 terminal bridge rectifier. They probably use the same thing in your supply.
Let me know if you have any other questions.
Nov 15, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pyramid ps-21k power supply
you need to get the voltage regulator circuit checked in your ps-21k
Jun 13, 2008 | Pyramid 10 AMP 13.8V POWER SUPPLY Car...
WILL NOT TURN ON
Likely a bad power supply. If it uses the same PS as the L6 it's part # is adp-60cf. The PS is used in numerous vizio models including the p42. Check the output plug on the PS, pins 1 & 2 should be 16V, and 3 & 4 are ground. There is also a slo-blow fuse soldered onto the board very close to the AC in plug.
Sep 04, 2007 | Vizio L6 20.1 in. HD-Ready LCD Television
Pyramid PS14KX 270-Watt Power Supply Logo
254 people viewed this question
Top Pyramid Computers & Internet Experts
BJ Russell
Jason Morris
Are you a Pyramid Computer and Internet Expert? Answer questions, earn points and help others
